C5 computer tunning
Old Apr 26, 2018 | 09:09 AM
Waldo73's Avatar
Waldo73
4th Gear
Default C5 computer tunning
Does anyone know it by changing the transmission from mechanic to automatic do I have to do any tuning to the computer please help me out with this I am newbie so I don't know much about it
Old Apr 26, 2018 | 10:12 AM
SG Lou's Avatar
SG Lou
Yes, along with a few other changes....I'll let World Class Corvette GM Technician Paul Koerner explain:
HI there,
There are a number of factors to consider here.
#1, wiring. The six speed manual has much less wiring than a comparible automatic transmission. The 4L60-E, which is what could be installed, requires a different engine control module and the correct wiring to run down the torque tube to operate the transmission. The ECM will also have to be reprogrammed correctly.
#2, ABS/active handling systems will have to also be programmed correctly for this change.
#3, your rear differential can be used, but I do not recommend it as this would require aftermarket programming which has not been shown to be accurate enough for long term reliability of the powertrain.
#4, center console changes would necessitate purchase of the shifter assembly and cable to the transmission. Lighting to the shifter PRNDL will also have to be wired in.
#5, removal of the clutch pedal assembly and installation of the correct brake pedal would also be important here for comfort of the driver.
A preliminary cost analysis is about $10,000 between wiring harness, transmission, differential, PCM and pedal assembly, including some, but not all labor costs.
THE MOST IMPORTANT ASPECT in most owners view, is that every single part of this car will have to be removed. Entire powertrain removed to correctly replace the wiring harness. The entire interior including dash, carpeting, seats to correctly run the body harness for the changes.
I do agree with others here, a different automatic equipped vehicle would be a better option, IMO.
Allthebest, Paul
GM World Class Certified Technician.
Like us: www.facebook.com/corvettemechanic
http://twitter.com/GMvettemechanic
http://thecorvettemechanic.com "
Old Apr 26, 2018 | 10:24 AM
Moved to C5 Tech.
Old Apr 26, 2018 | 10:27 AM
JR-01's Avatar
JR-01
Are you planning to change your transmission from mechanic to automatic yourself? If so,you may want to rethink it.
Old Apr 26, 2018 | 10:34 AM
SG Lou's Avatar
SG Lou
I think that once he reads what I posted he will rethink it
Old Apr 26, 2018 | 10:39 AM
SG Lou's Avatar
SG Lou
Originally Posted by 8VETTE7
If the Thread Starter really has to have a manual trans C5, he would be a lot better off financially to trade the auto and find a manual.
I thought the same thing Buddy
Old Apr 26, 2018 | 10:54 AM
JR-01's Avatar
JR-01
It takes some major skills to swap out trannys in these cars.
Old Apr 26, 2018 | 11:46 AM
Waldo73's Avatar
Waldo73
4th Gear
Default Shifter cable
Do you happen to know what kind of bracket or it has to be prefab the bracket goes next to the shifter that holds the cable for the shifter to the tranny. Thanks a bunch
Old Apr 26, 2018 | 11:52 AM
SG Lou's Avatar
SG Lou
Did you read the list of items that needs to be changed in order to do the swap ? Shifter bracket is the least of your concerns .
Old Apr 26, 2018 | 11:59 AM
JR-01's Avatar
JR-01
I think this guy is trolling us. Unless he believes all you have to do is change the shifter from a manual to an automatic..
Old Apr 26, 2018 | 12:20 PM
lionelhutz's Avatar
lionelhutz
Wow, nice responses. Lots of people have done the swap. It's time intensive, but not that terribly hard to do.
To answer the original question, you have to reflash the PCM to an automatic transmission tune.
Old Apr 26, 2018 | 12:25 PM
midnight01's Avatar
midnight01
No bracket necessary bro! Just get your new or used manual shifter and make sure you get the cover and all that good stuff like new center console plastic and bolt it on. Once you take out the auto shifter and all relevant plastic you will see how easy it is!
now as far as everything else? Let us know how that worked out for you.
Old Apr 26, 2018 | 12:36 PM
JR-01's Avatar
JR-01
It really does not sound like the OP has the skillset to do the job.(He really doesn't seem to have a clue). It really is a big job and not for the inexperienced. Just trying to save him some grief and stop him from tearing the car apart. Encouraging him to do something he will regret is irresponsible.
Sell the car and get an auto. There are a lot of them out there.
Old Apr 26, 2018 | 01:49 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Unless you have a wrecked parts car to get ALL the required AUTO PARTS from, this is a VERY expensive and time consuming project.
It also has to be a parts car in the specific year that yours is as some wiring differences exist between different years.
You could call one of the forum wrecking yards and see if they can give sell you a swap package with all the parts necessary.
Hell, there are even some parts needed to be converted INSIDE the DIFFERENTIAL!
YES the PCM will need to be flashed to an A4 configuration. That's the EASY PART!!
Good luck my friend.
Bill
Old Apr 29, 2018 | 07:51 AM
Waldo73's Avatar
Waldo73
4th Gear
Default No shift gears
Can you tell me what problem could be that our c5 it's no shifting gears only on 2 n 4 gear, we replaced it from mechanic to automatic, we tune the computer, the tranny was replaced and rebuild, install cable shifter accordingly but we encounter this issue that is not shifting gears, what could be the issue ??
Old Apr 29, 2018 | 09:44 AM
JR-01's Avatar
JR-01
Good luck.
Old Apr 30, 2018 | 12:17 AM
tanisdwninit's Avatar
tanisdwninit
WTT thread would net a better result with much less of a headache and hit to the wallet I suspect as mentioned, or straight up sell the 6 speed and buy the less expensive AT.
To C5 computer tunning
Old Apr 30, 2018 | 01:16 PM
lionelhutz's Avatar
lionelhutz
It could be the transmission, wiring or PCM.
There is no common part failure that results in a 4L60e only shifting between 2nd and 4th gears.
IF you actually put together a clear concise post detailing the issue you might get more detailed and useful answers. Right now, your unclear and uninformative blurbs are mostly useless to work with. From your first post until now I highly doubt you decided to do the swap, did the swap and rebuilt the transmission so it's become obvious your first post was after you've been struggling with an issue. Yet, nothing about that was posted.
Old Apr 30, 2018 | 04:33 PM
SG Lou's Avatar
SG Lou
I'm glad someone else said what I was thinking..........
Old Apr 30, 2018 | 07:51 PM
JR-01's Avatar
JR-01
I was thinking it, too.
