Trunion upgrade = more noise
Old Apr 28, 2018 | 06:44 PM
bwill03z's Avatar
bwill03z
Default Trunion upgrade = more noise
Has anyone had more valve train noise after doing the trunion upgrade? I had mine done recently with the BTR kit and the sewing machine ticking is noticeably louder. It's not a big difference and doesn't sound real bad but there is a difference. Anyone know why this would be?
Old Apr 29, 2018 | 01:17 AM
TastyBacon's Avatar
TastyBacon
Sorry, but aftermarket needle-bearing rocker trunnion kits are bad news. I believe they should be avoided:
https://www.corvetteforum.com/forums...n-upgrade.html
https://ls1tech.com/forums/generatio...12k-miles.html
https://www.corvetteforum.com/forums...re-summit.html
Old Apr 29, 2018 | 07:28 AM
feeder82's Avatar
feeder82
The BTR kits are bushing style
Old Apr 29, 2018 | 10:35 AM
bwill03z's Avatar
bwill03z
Feeder is correct these are bushing style
Old Apr 29, 2018 | 04:15 PM
StingrayRebel's Avatar
StingrayRebel
perhaps it's just transmitting more noise than the factory rockers from your lifters tapping... it seems like you have tried everything else possible to fix your tapping issue except for changing what you presume is the root cause (the lifters)... if you are that concerned you should take the heads off and swap them out, you were already part of the way there when you changed the trunnions
Old Apr 29, 2018 | 05:19 PM
evolmotorsprt's Avatar
evolmotorsprt
Did you change your cam and not figure out the correct pushrod length? It would make sense for your valve train to be noisy if your pushrods are the wrong length.
Old Apr 29, 2018 | 05:50 PM
bwill03z's Avatar
bwill03z
No.. cam, pushrods, springs, rockers are all stock.
Old Apr 29, 2018 | 06:48 PM
TastyBacon's Avatar
TastyBacon
Good deal. They used to sell a needle bearing kit. Glad they switched.
Old Apr 29, 2018 | 06:55 PM
MSUGTO's Avatar
MSUGTO
Did they switch recently? About a year ago I had installed their trunion upgrade kit and it was a needle bearing kit. Didn't see a bushing kit on their website, any info would be helpful!
Old Apr 29, 2018 | 07:47 PM
bwill03z's Avatar
bwill03z
Originally Posted by MSUGTO
Did they switch recently? About a year ago I had installed their trunion upgrade kit about a year ago and it was a needle bearing kit. Didn't see a bushing kit on their website, any info would be helpful!
I could be wrong but I had a shop order and install their kit thinking it was a bushing kit. I guess I should have verified that first. Does anyone know for sure what their kit is?
Old Apr 29, 2018 | 08:14 PM
bwill03z's Avatar
bwill03z
Ok so I am wrong, they are a needle bearing style kit.
Old Apr 29, 2018 | 09:19 PM
Dbl_D718's Avatar
Dbl_D718
​​​​​​Correct, the BTR kit is needle bearings. A friend of mine installed these, and the new bearings felt significantly notchier than stock in my hands. I have not heard the car run with them installed yet, though, so I'm not sure if it translated to more noise.
He called BTR and discussed the notchiness with them, they assured him that it's normal.
Old Apr 29, 2018 | 09:23 PM
bwill03z's Avatar
bwill03z
That is probably why mine is noisier now... I don't know what else would cause it. It's not a big deal though it's not alot worse just slightly.
Old Apr 29, 2018 | 09:48 PM
MSUGTO's Avatar
MSUGTO
When I stalled my kit from BTR, all felt great except one rocker which felt notchy. I called BTR, they sent me two new bearings and the rocker felt nice and smooth, not sure what the issue was.
To Trunion upgrade = more noise
