I am having an issue with my battery draining. Even after being on charge all night, car won’t start. Battery tested ok, but put a new battery in last night and drove with no issues. Car wouldn’t start the next morning. Any ideas?
Reason: simplifying post
First thing to do is disconnect negative battery cable and connect DVM in series with negative battery cable and negative battery terminal. Select DC amps on meter and measure sleep mode current after 15 minutes or so, sleep mode current should be about 25-30 milliamps. Common issues that cause excessive current drain can be power seats, audio amps, alternator, and headlight modules, of course you can pull fuses observing DVM while doing so, hope this helps.
I have a question my battery which is only a year old goes dead and will not start my 02 after 2 weeks. I checked my amperage draw and I have zero mil-amp draw and I hooked it up just like the instructions say to. I have my meter on DCA on 10 amp scale and I get zero discharge, so is it battery problem ? I had the battery checked and got a OK on the battery.
I would double check the lead connections on your multi meter to make certain they are set up to measure amps............
If the leads are correct you may have to step down to a scale less than 10A. The draw should be small and not knowing which meter you are using you may have selected a scale too high to sense the normal small draw.
I have two scales, a 10 amp and a 2 amp and I've tried both scales. I may have a bad meter, I'll try another meter this weekend.
Most likely that the fuses for both amp current ranges are bad, since the meter is connected in series when measuring current there are two internal fuses to protect the meter in case of very high current draw, I would open the meter and check the fuses, might save you the cost of a new meter.
Yes sir fuses were blown in the meter. had to order them as they are special.
Replaced the two fuses and now I get a reading of .02 on the 10 amp scale which I assume is 20 miliamps. So I guess I don't have a draw after all just a week battery maybe, I would have thought the battery would have held up after 2 weeks as it's less than a year old.
Yes moving the decimal point three places back will give you 20 milliamps which is with in spec for sleep mode current draw. I would have your local auto parts store charge and load test your battery before buying a new one just in case, not unheard of thou that sometimes you can buy a new battery that will fail within a year or two.
