Creeking in rear suspension
Old Oct 17, 2002 | 05:46 PM
quimbo's Avatar
quimbo
Default Creeking in rear suspension
98 with 69000 miles on car anyone else have creeking in the rear suspension?
QUIMBO :rolleyes: :rolleyes: :seeya :seeya
Old Oct 17, 2002 | 05:58 PM
pewterhdtop's Avatar
pewterhdtop
Default Re: Creeking in rear suspension (quimbo)
Just solved the same problem with my 2000. It turned out that there was a considerable amount of sand/dirt between the bushings and the sway bar. Removed the sway bar and bushings, cleaned both surfaces, and reinstalled the bushings with a very light coating of Amsoil Series 2000 racing grease (Lithium) and I now have silence! :cheers:
Old Oct 17, 2002 | 06:05 PM
quimbo's Avatar
quimbo
Default Re: Creeking in rear suspension (pewterhdtop)
Hey pewterhdtop thanks for the tip I will try that any problems with removing the sway bar?
QUIMBO :cheers: :cheers:
Old Oct 17, 2002 | 06:20 PM
pewterhdtop
No problems at all, just watch the end links. :cheers:
Old Oct 17, 2002 | 08:09 PM
ifeeltheneedforspeed's Avatar
Default Re: Creeking in rear suspension (TexasRedY2K)
I had the same problem, and it ended up being loose bolts in the cradle that connects the suspension to the frame. There are two bolts on each side (four total) and are very easy to access. All four were loose. The car had never had these removed. The torque is 82 foot lbs.
To Creeking in rear suspension
