1635 code
Old May 3, 2018 | 07:54 PM
robert1989's Avatar
robert1989
Default 1635 code
Had a loose spark plug wire causing a miss fire like an idiot I pushed it off completelu and the ignition coil started to spark to the valve cover. I quickly turned engine off. Now I have the 1635 code sometimes C some times HC.
Some times I catch the code come up with a p0101 and disappear. I'd guess that the map is fried but that's plastic so doesn't make a lot of sense.
Any ideas?
UPDATE: the a/c pressure sensor only shows 2.9 volts on the reference and is suppose to be 5 volts.
Guessing bad PCM?
