PCV Mod
Old Oct 17, 2002 | 09:39 PM
gojo's Avatar
gojo
Default PCV Mod
I just did the PCV Mod. It was real easy and took 20 minutes.
parts needed: 2 1/2 feet 3/8 air line. 2 clamps. 2, 3/8 barbed fittings. 1 filter from McMaster Carr catalogue. I like this filter because it has a screw tight drip hole and can be opened and closed without removing the bowl.
I used a copper tubing cutter and a sharp blade. I cut the pcv plastic pipe just past where it bends so that I could turn it up for clearance. Just slide the hose over the pipe on the other end. Put on tie downs and your done.
http://www.shutterfly.com/osi.jsp?i=...21b308c82425a0
Old Oct 18, 2002 | 07:16 PM
zoomnz's Avatar
zoomnz
Default Re: PCV Mod (jfpilla)
Looks Great...One question?? Does the pcv valve go before the filter or after the filter?? Or does it matter?? Looks like you have yours after the filter..Most of the pics I have seen have the pcv valve before the filter??
ZOOMNZ
Old Oct 19, 2002 | 09:50 AM
zoomnz's Avatar
zoomnz
Default Re: PCV Mod (zoomnz)
Anyone..? Anyone...?
PCV Valve before the filter..??
PCV Valve after the filter..??
Or does it matter...?????
ZOOMNZ
Old Oct 19, 2002 | 10:10 AM
MelloYellow's Avatar
MelloYellow
Most put the PCV valve before the filter due to tubing.
It should work fine either way.
Old Oct 19, 2002 | 10:20 AM
Rx7Rob's Avatar
Rx7Rob
Which McMaster filter did you use?
Old Oct 20, 2002 | 04:26 PM
gojo's Avatar
gojo
Sorry, been away. The filter is before the pcv valve. Hopefully it will stay clean longer.
Will post the McMaster info monday after work.
[Modified by jfpilla, 3:27 PM 10/20/2002]
Old Oct 20, 2002 | 04:30 PM
gojo's Avatar
gojo
Default Re: PCV Mod (Rx7Rob)
Put it up Rob, anybody who doesn't want to look at pictures can make that choice under user options.
Old Oct 21, 2002 | 07:50 AM
Rx7Rob's Avatar
Rx7Rob
Had that sig file for so long I didn't have a clue what you were talking about :-).
But, which McMaster filter did you order????
Old Oct 21, 2002 | 12:56 PM
gojo's Avatar
gojo
I was told at work that the filter is from Grainger. Unless you have a commercial account you can't buy from them. If you have access, the filter is a Speedair # 2z766 pg 2945 of their catalogue. You can also get the same type from Lowes and Home Depot.
[Modified by jfpilla, 12:00 PM 10/21/2002]
To PCV Mod
