Multiple codes set
Old May 9, 2018 | 03:42 PM
Steve.in.Roanoke's Avatar
Steve.in.Roanoke
Default Multiple codes set
2000 C5 Vert, 65,000mi. Last evening mild on ramp acceleration.
Zap! Reduced engine power, running rough. Limped into gas station.
Rested for a few minutes, showing ASC & ABS on read out. Re started & check engine light popped on.
Filled tank w/ high test & drove home. Pulled codes = P1120, P1220, P1515, P1516. Info here says throttle position sensor PCM / TAC module. Cleared codes & all is fine at the moment.
Any experience with this challenge?
