Will Using a MAF Backwards Ruin It?
Old Oct 18, 2002 | 12:25 AM
Big Carrot's Avatar
Big Carrot
Default Will Using a MAF Backwards Ruin It?
I got in a hurry and put my maf on backwards the other day. Now it's messed up. Can I attribute that to having it on backward for a couple of hundred miles? :conehead
Old Oct 18, 2002 | 01:46 AM
NJVetteGuy's Avatar
NJVetteGuy
Default Re: Will Using a MAF Backwards Ruin It? (Big Carrot)
I don't think you can damage it by installing backwards...correct the installation, reset the computer and see how the car is after that. Chances are it will run fine :yesnod: If not, it's probably something else or one of the elements in the MAF got touched and broken during the r&r. Good luck :cheers:
Old Oct 18, 2002 | 03:06 AM
Barely Legal's Avatar
Barely Legal
Default Re: Will Using a MAF Backwards Ruin It? (NJVetteGuy)
Not at all. You just look :jester
Big Carrot's Avatar
Big Carrot
I tried that. It just started running like crap, so I figured I had an air leak. I tightened everything and then duck taped all the seams and nothing helped. I think the MAF is fried somehow. I wouldn't think it would hurt it, but I have no other explanation. :confused:
[Modified by Big Carrot, 1:11 AM 10/18/2002]
To Will Using a MAF Backwards Ruin It?
