Fuel tank
Old May 11, 2018 | 07:26 PM
gbusha's Avatar
gbusha
Default Fuel tank
Anyone know how the fuel from the right side fuel tank tansfers to the left tank? Also how does fuel fill the right side fuel tank?
Old May 11, 2018 | 08:26 PM
redzg's Avatar
redzg
So every time the car sits, the fuel self levels between the tanks, and then anytime the power is on the R/H tank is emptied into the L/H tank, with the computer reading both float levels and calculating how much fuel it thinks you have remaining. So when I start my '99 with less than half a tank, the gage often slowly goes up for the next several minutes...
Old May 11, 2018 | 09:29 PM
JR-01's Avatar
JR-01
Talk about making something as simple as a gas tank, so much more complicated than it needed to be.
Old May 12, 2018 | 08:42 AM
redzg's Avatar
redzg
I agree -- though I'll assume the engineers were thinking of something I don't understand. To my mind, if it drained both tanks equally, it would make sense. Then the weight would be distributed and as low as possible. But always keeping the most fuel in one tank seems asymmetric and illogical.
Old May 12, 2018 | 10:43 AM
gbusha's Avatar
gbusha
Thanks guys i think i have it, sometimes slow to put it together.
I had to change the fuel pump assembly in the left tank because of a weep at the gasket. With 62000 mile wonder if i should change out the right tank??
Lazarus Long's Avatar
Lazarus Long
They should have put the filler/primary tank on the passenger side though.
Old May 12, 2018 | 10:54 AM
JR-01's Avatar
JR-01
Originally Posted by 8VETTE7
If the design were a bad one then GM would have most likely changed it for the C6 and/or the C7.
In fact the exact same fuel tank system that was implemented for the mid model year 2003 and entire model year 2004 is STILL in use on the C6 and C7 Corvettes.
Seems like there are too many things that can go wrong and sometimes they do. I have never had any problems with any other car's gas tank or have heard of anyone that has. GM probably spent a fortune designing it and did not want to spend another fortune designing another, so they just fix them when they fail, instead. Cheaper that way.
Old May 12, 2018 | 11:50 AM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
It isn't just Corvette using split-tanks either, there are a fair number in use both import and domestic.
Old May 12, 2018 | 12:36 PM
JR-01's Avatar
JR-01
How many other cars have you owned that had/needed 2 fuel tanks???
Did the Corvette really need 2 fuel tanks? A truck I owned had 2 fuel tanks. I just believe a fuel tank should not be something that can have problems.
Old May 12, 2018 | 12:53 PM
'Shifter's Avatar
'Shifter
NCM Member '09
It's a balance as well as room design. Where else could you put it without making the svelte car bigger?
Old May 12, 2018 | 01:15 PM
JR-01's Avatar
JR-01
They could have put one 9 gallon tank.
As stated above where would they have put a reasonable capacity single tank without either a larger car or stealing room from the already limited carrying capacity?
If you don't want problems with the fuel tank guess you should consider putting your C5 up for sale.
......or they could have designed it so there would be no problems. My C3 was smaller and I had no problems with the single tank and it even had a spare tire..
I am considering selling my C5, but the tank isn't the reason.
Old May 12, 2018 | 03:54 PM
Flightwriter's Avatar
Flightwriter
Cruising
The book "All Corvettes Are Red" has a detailed explanation of why this design was chosen, but it comes down to the simple fact that the dual tank setup was the best compromise that met the design criteria for the C5. A single 9-gallon tank would unacceptably limit range, and fitting an 18-gallon tank would have meant having it sit on top of the rear transaxle assembly, cutting deeply into rear cargo space, and it may not have met crash standards.
Old May 12, 2018 | 04:07 PM
wdcraig's Avatar
wdcraig
The Corvette doors are long; so I soon found that pulling up to the pump on the driver's side can make hitting the door on the pumps or pump protective posts very likely. Where it possible (Costco), I will pull up to the pump on the passenger side and pull the hose over the trunk and fill up. Makes getting out of the car to fill it, much easier.
Old May 12, 2018 | 04:27 PM
'Shifter's Avatar
'Shifter
NCM Member '09
The filler location doesn't bother me, I'm just glad that they didn't put it on top of the body (horizontally, like previous gens)....
Old May 12, 2018 | 05:10 PM
Moved to C5 Tech.
Old May 12, 2018 | 06:40 PM
redzg's Avatar
redzg
I agree. Never understand fuel doors on the wrong side of the car.
To Fuel tank
