Two issues. Not sure if they are related. Blinkers will go out while driving. I will go to turn on the signal, and nothing. If I push the hazard button it will reset and most times allow them to work.
Any Thoughts?
Second question, with no rhyme or reason rarely the car will not start then I turn the key. I move into and out of gear and move the steering wheel, press the brake, whatever, and after a few minute delay, it will turn over and start.
Thanks guys. While posting in the right section is preferred, it sometimes take a while for newer members to explore all that CF offers and determine exactly where a post goes. I'm moving this over to the C5 Tech section.
Thank you[/QUOTE]
I once had a problem with starting, even tried licking the key. Turned out to be the solenoid/starter
