What ties these electrical gremlins together?
Original problem: around the time (but not exactly) I replaced my tail lights with LED, I began getting a traction and stability control warning. I eventually deduced that this occurred only when I used my hazard lights while driving. Brake lights, turn signals, etc. no problem, and no problem using hazards when stopped. These systems are then disabled until I turn off and restart the car. This is a fairly common problem and I've read up on it, seems likely to either be bad ground somewhere or the supposedly already-compensated LED taillights need additional resistors.
Recently: I've continued to drive it, avoiding using the hazard lights (and they're the "thank you for letting me pass" signals in the mountains here), without problem. Then one day after a hard acceleration over bumpy ground I got a "service vehicle soon warning" and "charge system fault", as well as TC and SC disabling, AND now ABS warning too. Same as before I restarted and most of the errors went away, though the service vehicle warning showed upon starting. (Also I got a low engine oil warning and in fact it was 1.5qt low. Maybe that's just coincidence? No signs of a leak or smokey exhaust. It'd been a while since I checked the level.)
Today I decided to drive it in to work and just as I picked up speed it started spewing warnings and then the whole display shut off, though HUD still worked. When I returned to idle it powered up again. The voltmeter was showing 16 to 18V when it was working! I got the "charge system fault" again and now also "high voltage." Seems like my voltage regulator failed? Could that be related to all of my other problems? Returned home and parked it of course.
I have a Tech2 but haven't hooked it up yet to investigate. I'm dedicating at least one day this weekend to car maintenance so I'll do that. Does anybody have any theories about what's going on with this thing? Could the voltage regulator be the root of it all, or could bad grounds (my leading suspect between the 2nd and 3rd symptoms) kill the voltage regulator in addition to all the rest?
Thanks for any ideas!
and yes having had three fiberglass cars, bad grounds will screw with you more then you can imagine
bobs77vet, haven't tried yet but plan to. It just mystifies me that the hazards would do it but brakes and signals don't if it is just an LED issue.. I've had a 77 and a 70, tell me about it! Good grounding isn't that hard but they always seem to skimp on it.
...Today I decided to drive it in to work and just as I picked up speed it started spewing warnings and then the whole display shut off, though HUD still worked. When I returned to idle it powered up again. The voltmeter was showing 16 to 18V when it was working! I got the "charge system fault" again and now also "high voltage." Seems like my voltage regulator failed?...
Regarding the overcharging messages and the 18v etc. it might be bad contacts as well, in the alternator-starter-battery chain. This is a quote from a thread that was describing almost exactly what is happening to you. I think it's worth a check.
My last car before the C5Z was an '06 M6! Glad to have experienced it but probably good I totaled it before it became a maintenance disaster. Car work day tomorrow!
(Note: no idea if the door speaker is working, which could implicate the 10-pin connector, as the radio has been out awaiting a new head unit install for all this time.)
