HVAC Vacuum Problem INSIDE
Old May 19, 2018 | 03:41 PM
unlvrebel's Avatar
unlvrebel
Default HVAC Vacuum Problem INSIDE
I have the dreaded cold air from all vents issue. But my vacuum issue is inside the car. I checked for vacuum where the purple line connects to the supply. With the car running I get 16 inches of vacuum.
I then tested vacuum on the purple line with the car running and with the car not running. With the car running, I was not able to pull any vacuum. Squeeze the handle and nothing. With the car turned off I was pull 15ish inches of vacuum that would bleed off about an inch peer second.
Has anyone run into this issue? Could use a little help.
Thanks!
Old May 19, 2018 | 06:04 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
do you think its in the control valve on the side of the heater box above the blower fan? you also have a HVAC vacuum canister located behind the RF fender
Old May 19, 2018 | 07:25 PM
unlvrebel's Avatar
unlvrebel
Hmmmm... I don't think it is the canister as I have vacuum past that point (inside the car). I suspect that the vacuum issue is from the purple input to where ever the final spot that vacuum is used... But I don't know what that is...
Bill Curlee!!! Are you out there?
To HVAC Vacuum Problem INSIDE
