Another Window Issue
Old May 20, 2018 | 05:05 PM
BRAVO1's Avatar
BRAVO1
VETERAN
Default Another Window Issue
The windows on both doors rattle when you close it especially when down. You can move the window grasping the top and move it slightly back and forth. Seems like the rubber part at the bottom of the regulator is old and doesn't hold the window tight. I pulled the door card on the drivers side to see what the problem is but didn't really see anything missing. Also to sound deaden the door. Any thoughts, do I need to get a new regulator to tighten the window base ??
Jim
Or is this something us C5 owners must deal with........
Old May 20, 2018 | 10:54 PM
Moved to C5 Tech.
Old Jul 11, 2018 | 01:39 PM
jamesbii's Avatar
jamesbii
did you fix your issue yet? I've got the same issue w/ the driver door, when the window is down and I hit a bump, i get a rattle. When the window is up...no rattle.
To Another Window Issue
