Anybody familiar with this noise?
http://https://youtu.be/LEfj8C_KW-0
Just changed my Harmonic Balancer (Powerbond PB1117N), along with a GM Torque to Yield bolt, Oil Pan Gaskets, Front Main Seal and Cover Gasket, and a Gates Serpentine belt this past weekend, good news, Oil Leak is gone completely, bad news, I have this squeak that starts after the car has been driven quickly. The Balancer also seems to have some wobble to it, so what gives?
Zen Vet Master Level VII
The video is not loading on my computer... maybe others as well?
If you just changed your HB, you should have no (zero) wobble. Without the benefit of the video I bet your squeak is related to the wobble (it usually is).
Since you just installed things last weekend, there may be a chance that you may have a HB alignment issue. Double check and check back.
https://www.youtube.com/watch?v=LEfj...ature=youtu.be
I fixed your link, cant really tell by your vid if it is wobbling but perhaps a pulley or tensioner failed in the process
