Driver's side mirror issue
Old May 24, 2018 | 12:40 PM
swampmonster's Avatar
swampmonster
Default Driver's side mirror issue
Whenever I use my remote to unlock the car, the driver side mirror starts moving around and always ends up in the wrong position. It's not a memory issue because I would manually move the mirror in the correct position then save the setting but it keeps moving.
I tried searching for this issue but couldn't find anything similar. Does anyone have any idea how to fix this problem?
Old May 24, 2018 | 02:37 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
You may be using the wrong key fob for the wrong settings. Each fob has its own settings for driver 1 and driver 2.
Old May 24, 2018 | 03:09 PM
rrwirsi's Avatar
rrwirsi
I had the same issue with the mirrors even after turning off all the auto stuff in the DIC. So now I just use my key to unlock the car. Problem solved.
Old May 25, 2018 | 03:39 PM
swampmonster
I considered that but unfortunately, that's not the case.
Old May 25, 2018 | 03:40 PM
swampmonster
I just started using my key as well to unlock the door. But there has to be a fix for this!
Old May 25, 2018 | 06:24 PM
corvettezman
Did you try unplugging the battery for an hour or so and let everything reset? Just a thought.
Old May 25, 2018 | 09:00 PM
cadwiz_01Z's Avatar
cadwiz_01Z
Veteran: Marine Corps
From: When Democracy becomes tyranny, the armed citizens will still get to vote!
I've read that it has to do with the potentiometers in the mirror for the position feedback. I don't have a link to the thread, but it was on here somewhere. Basically, they get "contamination build-up" on them and give "false" location readings. The fix is to remove the mirror glass and move the potentiometers in and out by hand to remove the build-up. Not sure how well that works as I have never done it. I would think that a contact cleaner would work really well, but I don't know how that would affect the other parts inside the motor housing. I need to change my mirror glass pretty soon and will try it then.
edit: found the fix thread - link
Old May 29, 2018 | 06:25 PM
swampmonster
Yes, I've tried that directly, because I had to change out my battery not long ago.
Old May 29, 2018 | 06:29 PM
swampmonster
Sweet! Thanks, I'll take a look at it!
To Driver's side mirror issue
