my corvette keeps chirping
Old May 26, 2018 | 03:27 PM
rdizon1998's Avatar
rdizon1998
1st Gear
Default my corvette keeps chirping
my corvette 1998 keeps chirping randomly all during the day...any advice??
Old May 26, 2018 | 03:28 PM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
It's 90% chance it's your harmonic balancer.
Old May 26, 2018 | 03:30 PM
grantv's Avatar
grantv
Belts, pulleys, HB...
Can you post a video? Check for HB wobble while idling. Good place to start.
P.S. how old and what brand are the belts, and how many miles on the car?
Old May 26, 2018 | 04:12 PM
mrlmd's Avatar
mrlmd
Spray a little water on the main belt while the car is running. If it stops then it's related to that belt.
Does it only chirp on startup or after it warms up too?
Old May 26, 2018 | 04:45 PM
Smoken1's Avatar
Smoken1
Pull your belts off 1 at a time and see if if the noise stops. It could be any of these
Old May 26, 2018 | 06:48 PM
Moved to C5 Tech.
Old May 27, 2018 | 12:14 PM
LeaderP's Avatar
LeaderP
Did you replace the battery on the key FOB?
If so, the old ones with the passive entry feature default to ON even if the switch is in the OFF position after removing the battery.
Switch it ON and then back OFF and see if that stops it.
Old May 27, 2018 | 09:40 PM
grantv's Avatar
grantv
Yes, that kind of chirping... he hasn't replied since the original post.
To my corvette keeps chirping
