Battery replacement
Old May 27, 2018 | 12:33 AM
StevieB's Avatar
StevieB
Default Battery replacement
____________________________________
Hi guys, I bought a new battery for my 1998 C5 coupe which I have already installed.
Now I can’t remember how to put the foam rubber and shroud back on.
It’s a long story because I took them off last year.
The physical size and side posts are the same as stock. I would appreciate any instructions. Thanks in advance,
Steve
Old May 27, 2018 | 01:17 AM
grantv's Avatar
grantv
Foam rubber and shroud? Sorry, no idea what this is...
Old May 27, 2018 | 01:45 PM
TorqueWinsRaces's Avatar
TorqueWinsRaces
Most likely the plastic box thing surrounding the battery/fuse box area?
Old May 27, 2018 | 06:41 PM
StevieB's Avatar
StevieB
These are the parts I needed assistance with, see attached pictures. My previous terminology was incorrect.
GM OEM Battery-Heat Shield – GM (10268286)
AND THE Tray Insulator - GM (10246636)
Thanks for any assistance.
Old May 27, 2018 | 11:22 PM
glbeauchamp's Avatar
glbeauchamp
I tried to post before but it seems to have gotten lost somewhere so if it shows up I apologize in advance. Looking at the top picture of the heat shield. The hole in the upper left is attached to a large push pin located by the fuse block close to the passenger side fender. The tab with the hole in it on the upper right attaches to a push pin located on the passenger side of the windshield wiper cowling. The tab goes underneath the cowl. You can feel the pin under the cowling. The tab on the bottom goes into the top of a screw that attaches ground wires to the frame between the engine and battery area. If you get the shield in properly the holes should almost line themselves up. As far as the lower picture, I can't help you with that one as I don't have one of those on my car but it looks like it wraps around the battery somehow. It's hard to tell as the photo is fuzzy.
Old May 28, 2018 | 02:13 PM
StevieB's Avatar
StevieB
Yep, that’s correct. I have a link to the GM site that shows every part
that is used and where it goes. I posted the link but can’t get it to work here.
After looking it becomes obvious as to how it all goes together.
The Tray insulator is the foam rubber part I was talking about. That's the lower picture that's fuzzy. I had to copy it and couldn't get the picture sharp.
Why everybody doesn’t have all of this stuff is beyond me.
This is the link I'm talking about that i can't get to work.
https://www.gmpartsdirect.co/auto-pa...t/battery-scat
Old May 28, 2018 | 02:39 PM
stingray76l82's Avatar
stingray76l82
Try you tube
Old May 28, 2018 | 07:45 PM
StevieB's Avatar
StevieB
Originally Posted by stingray76l82
Try you tube
Next stop;
LUBE TUBE…………...
I figured it out and was at the point to just wiggle it around and bolt everything tightly down.
THEN I DROPED THE SOCKET WRENCH INTO THE HOLE TO HELL!!!!!
TOOK ABOUT 1 HOUR OF REMOVING THE BATTERY, LOOKING EVERYWHERE WITH A HIGH POWERED FLASHLIGHT………THEN FOUND IT.
Just replacing a battery turned into a total nightmare
Old May 28, 2018 | 08:33 PM
stingray76l82
Originally Posted by StevieB
Next stop;
LUBE TUBE…………...
Dam if you do not hear it hit the ground. It's a nightmare to find. Congrats
Old May 28, 2018 | 09:04 PM
glbeauchamp
Good to hear that you got it put back together. (P.S. Apparently the battery insulator was from 1997-2000, which explains why my 2002 lacks one.)
Old May 28, 2018 | 11:08 PM
StevieB's Avatar
StevieB
Thanks guys,
I have only had one other tool fall into the twilight zone. I thought I could hear where it landed, no such luck.
I Had to buy a telescopic magnet devise to find it. I couldn’t find the magnet devise today!!!!!!
As far as little things they may change;
I knew a guy that had a 99 with little changes in the engine layout.
His had the Location for the oil dip strip for instance. Mine has a place in the hood liner that is cut out to match the weather stripping on mine
HAPPY MEMORIAL DAY EVERYBODY
These cars are designed to drive people insane.
To Battery replacement
