clutch problem
Old May 28, 2018 | 10:08 PM
who928's Avatar
who928
Default clutch problem
01 c5 vert. put new clutch setup in .including flywheel clutch master and slave. . I have the same problem before I changed it . pedal stays on the floor when I get on it . Do I have to put after market clutch in it ? thanks. Joe R
Old May 28, 2018 | 10:17 PM
StingrayRebel's Avatar
StingrayRebel
in my opinion the only way to get rid of the shifting issues is to install a quality aftermarket clutch, it sucks that you had to go through all that trouble for nothing
Old May 28, 2018 | 10:46 PM
who928's Avatar
who928
Had some work on the engine for more HP and now can't shift it above 5000 RPM it sux
Old May 28, 2018 | 11:37 PM
StingrayRebel
the more power you add the worse it gets... how much power does it make now and what are your plans for the future?... the stock clutch can technically hold a decent amount of power but that's not the problem as you now know, the real problem is preventing you from being able to shift at high rpm... in my opinion the root cause of it is the self adjusting pressure plate
Old May 28, 2018 | 11:47 PM
who928's Avatar
who928
where up around 500 on the engine. I know that's not to much HP but its good for me. what would be a decent setup to put in it? We kicked the rev limiter up to 6700 from the stock 5700
Old May 29, 2018 | 12:02 AM
StingrayRebel
500 to the ground?... that isn't bad at all really, you might look into a mcleod rst or something like that just in case you decide to add more power later on... just stay away from factory replacements
Old May 29, 2018 | 12:06 AM
who928's Avatar
who928
I think I learned that. It sux pulling all that stuff back out to replace it again.
Old May 29, 2018 | 12:09 AM
StingrayRebel
with the mcleod you can get it without the flywheel for a pretty reasonable price and reuse your stock flywheel or if you don't mind spending a little more the billet steel flywheel is pretty nice and will save some weight
Old May 29, 2018 | 06:17 PM
SNL/MonsterClutchCo's Avatar
0SNL/MonsterClutchCo
Former Vendor
This issue is caused by the clutch slipping and imparting too much heat into the pressure plate, which causes the diaphragm spring to become heat fatigued, and can not push back against the hydraulics.
The issue is an under performing clutch.
Give us a shout if you want to go over anything.
To clutch problem
