Cooling question ? Hope someone can help...
Old Oct 19, 2002 | 02:30 AM
My2Dogs's Avatar
My2Dogs
Default Cooling question ? Hope someone can help...
The past few days our temperature has dropped to where you can drive with window down and air conditioning off.
Here's what I have noticed... When I turn off air the temperature gauge will climb to 220 and a little above if sitting in traffic and then when you get rolling it will come back down to about 180 which is the normal temp.
If I turn on Air the temperature gauge will never get over about 190 even sitting in traffic.
Today I was driving down town with Air off and noticed guage climbing again so I turned on the Air and temp started dropping.
Is my gauge gone nuts ? or maybe fan is not kicking in unless Air is on ? or
do I need to drink a beer ?
Help, warranty runs out on time limit next month although only 14,000 miles.
Also installed the Magnaflow X-pipe and Borla Stingers this morning. Yow, what a sound !! Engine seems to be run a lot smoother also.
Old Oct 19, 2002 | 03:01 AM
Richin Chicago's Avatar
Richin Chicago
Default Re: Cooling question ? Hope someone can help... (My2Dogs)
This is a wild guess but I believe the radiator fan is always on when the AC is. It is also, I believe supposed to kick on when the temp hits 190. It appears that the radiator fan is not being activated by the ccoolant temperatur sensor or whatever software is supposed to be doing that. I hope somebody else can give you a more definitive answer.
Old Oct 19, 2002 | 06:44 AM
Oldvetter's Avatar
Oldvetter
This is correct. When you turn on A/C, fan(s) come on. Otherwise fan is set to come on at about 230 F.
It does get worrysome, seeing temperature climb so high while sitting in traffic, but aluminum block and synthetic oil "likes/tolorates" these temperatures.
Old Oct 19, 2002 | 07:56 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: Cooling question ? Hope someone can help... (Oldvetter)
:yesnod: :yesnod: :yesnod:
This is completely normal... Nothing to worry about here.
vetterdstr :cheers:
Old Oct 19, 2002 | 09:36 AM
devo's Avatar
devo
St. Jude Donor '03 & '05
Default Re: Cooling question ? Hope someone can help... (Richin Chicago)
thats normal i freaked a lil when i noticed it too :crazy:
Old Oct 19, 2002 | 10:50 AM
Richin Chicago
OOPS! I believe it is the thermostat for the radiator that opens at 190! Sorry.
But while we are talking about cooling get under the car and see how much junk has made it to the top of that slanted radiator. Also between the radiator and air conditioning compressor.
To Cooling question ? Hope someone can help...
