frequency of oil changes
For those of you who want to do this I used a Cobalt drill bit and had to drill very very slow. I think it's stainless steel.
I re-use my own Mobil 1. I change both my corvette's oil once a year, they usually see less than 5,000 combined per/yr. So I save the oil and use it in my work van that'll easily get 3 changes a year. Over 250,000 miles in the van and it hasn't complained yet.
The article includes many anecdotal stories and experiences of the author related to the use of synthetics. One of my favorite stories is one related to a test sponsored by AmsOil (an early manufacturer of synthetic oil products) on a New York City taxi fleet. You may also find it interesting. Since it was sponsored by AmsOil, you can expect some salesmanship, but the outcome speaks for itself.
Initially the demonstration was to have required that each taxi, equipped with a Chevrolet 229 CID V6 engine, have its oil and filter changed every 3,000 miles. But Amsoil insisted that an alteration of the test procedure be instituted. The company's intent was to push its synthetic oil to the extreme and evaluate how it compared to the petroleum oils drained at the originally-specified, 3,000 mile intervals. The twelve Amsoil-lubricated vehicles were thus divided into three groups of four taxis each. Group 1 (Amsoil) would double the control interval, with oil and filter drain at 6,000 miles; Group 2 (Amsoil) would quadruple the control interval, with oil and filter drain at 12,000 miles; and Group 3 (Amsoil) would not change the oil *for the duration of the test*; thus multiplying the (petroleum) Control Group's drain-control interval by twenty times. In place of changing the oil, these (Group 3) cars would be equipped with Amsoil's ByPass oil filter, claimed by the company to keep (synthetic) oil analytically clean for up to 25,000 miles of driving, without replacing the element. The by-pass filter element was changed at 12,500 mile intervals for the duration of the test.
Following the year-long demonstration, each of the engines was disassembled, both to determine the levels of sludge, varnish, and rust that had accumulated inside the engine, and to carefully measure the amounts of wear experienced on critical engine components. Pictured on the previous page are representative samples of various components of the test engines. In the first example, the pistons and intake valves of the petroleum Control Group (*oil and filter changes every 3,000 miles*), are illustrated. The lower set of photos represent the same engine components from an Amsoil Group 3 vehicle. Note the substantially reduced varnish and sludge deposits on the synthetic-oil lubricated components, and the remarkably good overall condition of the Amsoil Group 3 piston rings and valves.
To summarize the findings and conclusions, the test facility responsible for the demonstration submitted this statement: "The data presented in this report indicates that the Amsoil synthetic SAE 10W-40 passenger-car motor oil formulation...provided protection of the test engines from excessive wear and deposit formation, far beyond the normal 3,000-mile change interval." In fact, the level of protection was such that those engines in which the original synthetic oil was run for the entire duration of the (60,000-mile) test showed less wear than did the Control Group vehicles using premium, 10W-40 petroleum oil and 3,000-mile drain intervals.
Good luck... GUSTO
For your engine, especially for the LS1, GM (AC-Delco) filters are probably the worst possible choice. The PF-46E filter has a flow capacity of 3 GPM. The LS1 oil pump flows between 4 and 7 GPM across most of the RPM range. So that filter is restrictive, and the bypass valve on the oil filter bracket pretty much runs open all the time. That filter almost never gets the full flow of oil from the pump.
The Wix 51042 (also Napa gold or Car Quest blue) is rated at 9 to 11 GPM. Most of the other aftermarket filters for this engine are rated over 7 GPM, so most will filter the full flow of the oil pump.
As to the rest of your post, if you're running oil for an extended time between changes, changing the filter at the factory change interval is usually a good idea, even if you don't change all the oil at that time.
I still recommend annual oil changes as a bare minimum. Condensation collecting in the oil can cause problems, and that happens even when the thing is parked.
