Spark Plug Help
Old Jun 6, 2018 | 08:22 PM
ttiros's Avatar
ttiros
Default Spark Plug Help
My C5 is a 2002. I have 40K miles and the plugs have never been changed. If the car is running good, when should the plugs be changed?
Old Jun 6, 2018 | 08:35 PM
ttiros's Avatar
ttiros
My concern is there age. Thanks for your help.
Old Jun 6, 2018 | 08:57 PM
Arvalo's Avatar
Arvalo
100k miles eh? I should probably do that since I’m at 99.3k
thanks for the tip!
does anybody have any good recommendations for plugs/wires?
Old Jun 6, 2018 | 09:11 PM
seattle's Avatar
seattle
I just changed my 2004 with 50,000 miles. The old plugs looked good but there was a questionable wire. It now runs smoother. You will need new wires. The old ones are PITA to get off.
Old Jun 6, 2018 | 09:32 PM
ttiros's Avatar
ttiros
Old Jun 6, 2018 | 10:21 PM
awches's Avatar
awches
I changed mine at about 113,000 I think. 3 wires came apart. One more fell apart and the plug for that cylinder had burnt the center electrode near flush. So as said, order wire set with plugs.
Old Jun 6, 2018 | 10:39 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
I would probably have the fuel injectors cleaned before I changed 40k plugs
Old Jun 7, 2018 | 12:32 AM
grantv's Avatar
grantv
I changed mine at 40K miles, but only because I was installing headers. If it runs fine, leave them IMO.
If you do replace definitely get wires also.
Old Jun 7, 2018 | 01:51 AM
Moved to C5 Tech.
Old Jun 7, 2018 | 01:54 AM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
I used the red OPM spark plug wires and the NGK TR55IX plugs
Old Jun 7, 2018 | 09:35 AM
knewblewkorvette's Avatar
knewblewkorvette
100K miles, age doesn't matter.
Old Jun 7, 2018 | 01:56 PM
ttiros's Avatar
ttiros
To Spark Plug Help
