AC blowing warm air
Old Jun 9, 2018 | 03:38 PM
James McKeen's Avatar
James McKeen
3rd Gear
Default AC blowing warm air
a.c. not working. Compressor has been checked twice. Fan motor works. Pulled the dash board out to check the blend doors. They seem to be working...I can see them move as I adjust the settings. I should be getting cold air but I don't. Anyone have any ideas? No a.c. in Florida is a mother...
Old Jun 9, 2018 | 05:25 PM
ant-knee470's Avatar
ant-knee470
IS the system full of Freon? Mine was doing the same thing just blowing warm air.. My friend is an A/C mechanic, He just did mine for $60.00.. Blowing cold as can be now, Where are you in Florida? I am located in Davie, If you are close my friend would probably take look at it for you...
Ant...
Old Jun 9, 2018 | 05:38 PM
James McKeen
3rd Gear
I thought the freon was checked twice but I'll probably have it checked again tomorrow. It's the only reason I can think of. I'm up in Port St Lucie.
Old Jun 9, 2018 | 05:39 PM
James McKeen
3rd Gear
...and thank you for your reply.
Old Jun 10, 2018 | 09:11 PM
grinditout's Avatar
grinditout
Is the clutch locking and spinning the pump?
Old Jul 1, 2019 | 07:56 AM
fake's Avatar
fake
First item to come to mine is sensor (out side) needs cleaning or replacement. Cleaning your condenser which is in front of your radiator which involves removing radiator.has a lot to do with your air conditiong
To AC blowing warm air
