Heads up display
Old Jun 19, 2019 | 09:34 PM
Bills01vett's Avatar
Bills01vett
Default Heads up display
I recently purchased a 2001 C5 with 65000 miles mint condition. However thr HUD does not illuminate onto the windshield. Is there a fuse or anything I should be checking?
Old Jun 19, 2019 | 09:46 PM
STRMLNE's Avatar
STRMLNE
Did you turn up the brightness left of steering wheel?
Old Jun 19, 2019 | 09:51 PM
Bills01vett
Yes, tried that. When I adjust the mirror up and down I can see it moving as well. Just no display on the windshield.
Old Jun 19, 2019 | 10:00 PM
STRMLNE's Avatar
STRMLNE
Do a search. There are dozens of threads like this.
https://www.corvetteforum.com/forums...eshooting.html
Old Jun 20, 2019 | 12:28 AM
Moved to C5 Tech.
Old Jun 20, 2019 | 10:50 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Time to get out the multimeter and figure what is and isn't getting to your plug in HUD:
Bill
Old Jun 29, 2019 | 02:53 PM
PattiShack3's Avatar
PattiShack3
Cruising
I have a 2005 c6 so i don't know if yours is the same as mine ? Mine doesn't work either. I 1st thought maybe a fuse. I can look down thru the windshield & can see it is trying to move. Someone told me they have plastic hinges that break & it isn't an easy fix. Maybe yours is different & a easy fix. So if are still having problems let me know.
Old Jul 1, 2019 | 08:21 AM
mark4cam's Avatar
mark4cam
Odds are really good that it does work, but it's fallen down and is pointing at the floor. Common problem, the pivot pin on the HUD is a little piece of plastic that breaks. You can tell if you go into a dark garage, then put your nose on the windshield and look very closely. I was certain mine was not illuminating until I did this, and I could see a very faint blue glow. That will confirm if you have the plastic pin problem.
You can see my pics on the repair here. Lots of good threads on here about removing the dash.
https://www.corvetteforum.com/forums...post1597047936
To Heads up display
