Ignition key lock cylinder
Old Jun 11, 2018 | 09:59 PM
NJD's Avatar
NJD
Default Ignition key lock cylinder
Need help on how to remove the Ignition key lock cylinder from the ignition switch.
Old Jun 13, 2018 | 06:36 PM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
Have you already removed the ignition switch from the car?
Old Jun 13, 2018 | 06:41 PM
3sACROWD's Avatar
3sACROWD
Once you have the switch and cylinder out of the dash, you need to insert the key and turn it a click or two. This allows you to depress the tabs on the side of the cylinder and cylinder slides right out. Hopefully that makes sense.
To Ignition key lock cylinder
