Drivers seat moves
Old Jun 16, 2018 | 03:10 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Default Drivers seat moves
Here something I've been meaning to look into. I have the "easy entry" option turned off, but whenever I get into the car, I have to move the seat forward about half an inch, or so I don't feel the seat moving back, when I get out of the car, but whenever I go to get back into it, the seat has moved backward.
Anybody have any suggestions as to what I should check??
Old Jun 22, 2018 | 03:40 PM
leadfoot4's Avatar
leadfoot4
Nobody??
Old Jun 22, 2018 | 05:36 PM
3sACROWD's Avatar
3sACROWD
Do you have the memory feature? If so, try resetting it after you move the seat back to where you like it.
Old Jun 22, 2018 | 05:54 PM
leadfoot4's Avatar
leadfoot4
I've tried that a couple of times, with no change.
Old Jun 22, 2018 | 06:36 PM
grantorino's Avatar
grantorino
Is the seat lower cushion bolster worn out? I had a car that the seat moved because the collapsed bolster would allow my A++ to push on the seat switch getting out. Is the seat side switch bezel broken or loose? If so, the switch could be depressed as you exit the car.
Old Jun 22, 2018 | 07:01 PM
leadfoot4's Avatar
leadfoot4
Good thought, but no, that isn't an issue.
Old Jun 24, 2018 | 06:54 PM
Cherry3m's Avatar
Cherry3m
I have the same problem. Mine doesn’t do it all the time, like once a week or so (daily driver). I’ve set the memory seat several times, and no improvement.
sometimes it seems related to how the door is locked or unlocked, by the door switch or key fob. I haven’t been able to repeat the issue on demand.
also, not sure if it’s moving when the door locks, or is unlocked. I try to remember to watch it when I lock/unlock, but I’ll forget, and that’s when it happens.
its quite maddening!
Old Apr 15, 2020 | 10:18 AM
George6418's Avatar
George6418
4th Gear
each key fob is programmed 1 2 or 3
each memory position ( 1 2 3 ) coincides with the fob
maybe your memory 1 but the fob you use is for memory 2 or 3
most came with 2 fobs
Old Apr 15, 2020 | 11:08 AM
Dbl_D718's Avatar
Dbl_D718
This. When you unlock the car using the fob, the seat moves to the memory position associated with that fob. It probably happens before you even open the door, so you don't notice. If you're always using fob #1, for example, make sure to save the seat position for memory 1.
To Drivers seat moves
