my FRC 1999
Old Jun 17, 2018 | 11:52 AM
99torchredlb's Avatar
99torchredlb
Default my FRC 1999
Lately, everytime I drive it my engine light comes on or the service traction control comes on............I clear the codes but it is becoming a pain in the ***........do I need a new computer or what........I live in a small town with small town mechanics........need some input thanks long time C5 owner
Old Jun 17, 2018 | 12:26 PM
3sACROWD's Avatar
3sACROWD
Listing your codes would help with the diagnosis.
Old Jun 17, 2018 | 07:29 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
This thread will be moved to the Tech section by Jack.
You say check engine light and also Traction. There are 2 different computers.
If you need a new EBTCM (Electronic Braking & Traction Control Module) they are only available used and cost between $1200 to $2400, and that's if you're lucky enough to find the same exact one you have. There are several ones made for a '99 depending on options.
But first, as mentioned already you should post the codes you have both active and history.
Old Jun 17, 2018 | 10:27 PM
Tusc's Avatar
Tusc
Running Guns & Moonshine
I, thankfully, do not have the problem with my car..... yet? Hopefully ever.
I haven't looked into it yet before. Which options affect which unit I would need?
Old Jun 17, 2018 | 10:56 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
On the top of the ebcm you'll find a sticker with a large letter such as V, M, or NK. You need to match the letter to the one you have on your car.
Example of the pump/EBCM bolted together. You can see the letter easily looking at the unit in your car. The pump rarely goes bad. The only part you need to replace is the half that has the letter.
Example of the EBCM itself. Different code
Old Jun 18, 2018 | 12:30 AM
Hope you get your answers over there.
Old Jun 18, 2018 | 09:16 AM
naturaldisaster3's Avatar
naturaldisaster3
Why would you clear the codes? What codes are showing up? Need more information before we can give you any useful advice.
Old Jun 18, 2018 | 09:48 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There are 20+ DTCs that the EBTCM can have. Some are easy to fix, some are not. PLEASE post ALL the DTCs in all the modules.
That will give us the proper info so that we can help you.
BC
To my FRC 1999
