"SERVICE ABS" warning
Old Jul 10, 2020 | 08:58 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Originally Posted by RED Coupe
Really nice gesture...thank you. Where are you? Oh, see you're in Monmouth, where about?
About 5 minutes off exit 117 !!
Old Jul 10, 2020 | 08:59 PM
RED Coupe's Avatar
RED Coupe
Originally Posted by c5 diag
about 5 minutes off exit 117 !!
gsp ?
Old Jul 10, 2020 | 09:00 PM
C5 Diag's Avatar
C5 Diag
gsp ?
yes !!
Old Jul 10, 2020 | 09:06 PM
RED Coupe's Avatar
RED Coupe
Thanks!!! Certainly will give you heads up if can come by. Of course I'm nut'sy **** about what weather I drive the car. No rain!!! haha
You'd think by now I'd relent about this. This has been most helpful!
Old Jul 10, 2020 | 09:12 PM
C5 Diag's Avatar
C5 Diag
Well Sunday looks like a good day...let me know...I can PM you my address and cell # !!
Old Jul 10, 2020 | 09:17 PM
Black 03 Z06's Avatar
Black 03 Z06
Great thread. Class act C5 diag.
Good luck with your issues OP. The electronics can be frustrating.
Old Jul 10, 2020 | 09:19 PM
RED Coupe's Avatar
RED Coupe
Thanks for kind offer....Sunday will be in NYC visiting one of me sons. Certainly not with the C5 of course, I never take into manhattan.
I can PM my cell, some when i endeavor to pull the codes I can get consultation. Ok?
Old Jul 10, 2020 | 09:24 PM
C5 Diag's Avatar
C5 Diag
OK, let me know !!...may be something like a wheel speed sensor or wiring but we need to look at codes !!
Old Jul 11, 2020 | 09:39 PM
RED Coupe's Avatar
RED Coupe
Just sent you a PM with code info....
Old Jul 12, 2020 | 01:10 PM
RED Coupe's Avatar
RED Coupe
Rob, thanks for the helpful guidance. Just performed the routine you suggested....cleared any codes that displayed, all were H category. Just drove
the car few miles, locally and highway. Went tru the code check routine and NONE there. Wondering is when I had brake fluid flush done at the
dealer(about 2+ years ago) anything to do with some of these H codes. Anyway, all is fine!!!! Thanks again for your generous offer of time. Bob
Old Jul 12, 2020 | 01:34 PM
C5 Diag's Avatar
C5 Diag
Bob, you’ve probably had those codes stored in history for years based on the fact the car is driven very little !!...some don’t clear for 50 ignition cycles and others for 100...if the TC/AH lights come on again just go through the DIC code retrieval and let us know !!
Old Jul 12, 2020 | 02:06 PM
rustyguns's Avatar
rustyguns
Not sure if I missed this suggestion in this thread but....First things First! Get a new battery that at full charge is is over 13 volts, 14 volts would be even better!! I use a computer controlled battery charger that gets close to 14 volts, got rid of my electrical problems. Also charge my battery once month to top it off! The electronics in these cars are cheap! And they are very sensitive to low voltage. I would ignore the door module errors, I get those all the time.
Old Jul 12, 2020 | 02:17 PM
  #33
RED Coupe's Avatar
RED Coupe
Thanks Rob....interesting point about ignition cycles. Yes, i'll keep an eye on whether anything pop's up.
Old Jul 12, 2020 | 02:31 PM
  #34
RED Coupe's Avatar
RED Coupe
Good points about sensitivity and quality of the electronics. When car was less than year old suddenly crazy things starting happening. Parked car, amazingly rear hatch release started cycling, headlights popped up and down, car wouldn't start. Flat bedded to dealer...defective battery. That replacement lasted many years since kept on trickle charger. Replaced that battery approx two years ago, still keep on trickle charger when not in use. Soon as car in the garage it goes back on the trickle charger(Battery Charger-Plus).
Old Jul 12, 2020 | 03:03 PM
  #35
rustyguns's Avatar
rustyguns
I have ruined many abattery with trickle chargers. what is the voltage on the terminals after you charge it? it it over 13 volts? after you drive it a couple days what is the voltage on the terminals?
you understand how smart battery chargers work? they charge and condition the battery, big difference from a trickle charger! google it!
Old Jul 12, 2020 | 03:18 PM
  #36
RED Coupe's Avatar
RED Coupe
I misspoke...product I use is called “Battey Tender Plus.
Old Jul 12, 2020 | 07:01 PM
  #37
Old School's Avatar
Old School
Red Coupe - since you were intermittently getting the 'SERVICE TRACTION CONTROL" AND "SERVICE ACTIVE HANDLING' message, did you have a C1214 code set?
To "SERVICE ABS" warning
Old Jul 12, 2020 | 07:16 PM
  #38
RED Coupe's Avatar
RED Coupe
No, did not. As explained earlier to C5 Diag(Rob), as directed I cleared all my codes(C1214) was not one of them. Drove the car and rechecked the system....no codes!
Old Jul 12, 2020 | 07:35 PM
  #39
Old School's Avatar
Old School
OK, just asking because C1214 is a common fault when you get those messages but is repairable.
Old Jul 12, 2020 | 07:38 PM
  #40
RED Coupe's Avatar
RED Coupe
Worthwhile info, thank you. Will be watching more closely now that I've been educated how to check.
