Active Handling warming up, doh!
Old Oct 20, 2002 | 03:08 PM
Quick Brick's Avatar
Quick Brick
Default Active Handling warming up, doh!
I have had the car for 2-3 months. It never gave this message in the warm months. Now I get it a lot even after arriving somewhere and starting back up. Durring the H/C job I drove it without the hood and it stayed in alert all the time. I figured it was because the IAT was cooler that the computer liked (it knew the hood was off). I think the Z06 front screens may be letting cool air to the IAT thus causing the active handling warming alert. Often it turns the dash indicator on and I have to restart or do a rolling reset to clear it. Any other info or help? Maybe I need to reprogram the tolerance on the system.. becoming a daily annoyance.. TIA :seeya
Old Oct 20, 2002 | 06:47 PM
vettenuts's Avatar
vettenuts
Default Re: Active Handling warming up, doh! (Quick Brick)
How are you driving it and when does it clear. If you drive under 12 mph for a length of time it will come on, but usually clears quickly once you speed up.
Old Oct 20, 2002 | 08:38 PM
C5King's Avatar
C5King
I've had the message come up before here and there, but only a few times. I don't know why it would come up all the time.
Old Oct 20, 2002 | 09:09 PM
chocoholic's Avatar
chocoholic
It's explained in your owner's manual.
Old Oct 21, 2002 | 10:14 AM
PaceThis's Avatar
PaceThis
When I had the dealer install headers, I kept getting this message (and it wouldn't go away). Turns out they screwed a sensor up and had to replace it...hope you didn't do this in your car, but you might want to check.
Old Oct 21, 2002 | 12:15 PM
jerryv's Avatar
jerryv
It's a normal message .. don't worry about it, as long as you get the 'warmup complete' msg a few seconds later.
To Active Handling warming up, doh!
