Power Seat Problem.
Old Jun 20, 2018 | 09:38 PM
UM Rebel's Avatar
UM Rebel
Default Power Seat Problem.
My daughter in law took my 2004 CE convertible to the store this morning. She moved the seat up some. Now it will not move back. All directions and lumbar support work, but it will not go back. I'm 6'2" and need it all the way back. Help!
Old Jun 21, 2018 | 09:13 AM
rrwirsi's Avatar
rrwirsi
I suggest check fuse #4 the passenger fuse panel (page 5-93 in owners manual). If the fuse is OK, then reach under the seat and make sure the electrical connectors are properly connected. Good luck on finding the problem.
Old Jun 21, 2018 | 09:16 AM
Black 03 Z06's Avatar
Black 03 Z06
Dumb thought perhaps but is there anything stuck behind the seat? Stuff can get wedged down behind the seat cushion that can be hard to see.
Good luck sorting it out.
Old Jun 21, 2018 | 09:26 AM
BRKLYN's Avatar
BRKLYN
Does it try to go back? I know that the rear mounting bracket against the console will brake, causing seat to fail and bind.
Old Jun 21, 2018 | 05:32 PM
UM Rebel's Avatar
UM Rebel
I think it's the switch. Every time I got in the car I tried to move the seat back. It wouldn't even try to move. Finally the last time I tried it moved all the way back. After that I pulled the seat fuse out. I understand passenger and driver side switches are the same. When I get a chance I'm going to swap them. Can anyone confirm both switches are the same? Thanks!
Old Jun 22, 2018 | 06:42 PM
grantorino's Avatar
grantorino
I have a feeling that once you swap switches, the seat will move opposite of which way you move the levers. I think the right switch is a mirror image of the left switch. If it plugs in then pushing the switch forward should cause the seat to move backwards!
Old Jun 22, 2018 | 10:26 PM
av8or's Avatar
av8or
There is a CB in the fuse box under the passenger foot well. It apparently controls the drivers seat. Last summer, 1500 miles from home, I stopped at a convenience store. When I shut the engine off, the seat automatically rolled all the way back, as it was programmed to do. When I got back in the car, the seat wouldn't move. I opened the fuse box, and the seat CB was too hot to touch.. I pulled it with a pair of needle nose pliers. There was no dealer close by..... after a while, in desperation, I put the now cooled down CB back in, and the seat moved! I quickly set the seat where I wanted it, and then pulled the fuse. When I got back home I bought a new CB...... problem fixed. May or may not have any bearing on your problem.
PS, A new CB from a dealer was about $12.
Old Jun 23, 2018 | 03:01 PM
UM Rebel's Avatar
UM Rebel
I pulled codes this morning. I think this pretty much confirms switch problem Thanks for responses and advice
B2197 Seat Reverse Switch Shorted to GND
To Power Seat Problem.
