Engine squeak
Old Jun 20, 2018 | 10:27 PM
Aug Air's Avatar
Aug Air
Default Engine squeak
I have a 2004 vert and I took it in recently and had the crank pulley and belt replaced because of a squeak. The squeak went away for a bit but is back and worse than ever. It is louder when the motor is cold and slowly goes away as the engine warms up. The squeak also gets louder when the A/C is turned on. Anyone have any suggestions on what this might be?
Old Jun 21, 2018 | 12:20 AM
grantv's Avatar
grantv
Remove the AC belt and run it, does it go away? Yes? It's the AC belt or pulley. No? Remove the main belt ... same test. Process of elimination.
What brand of belts? I put on brand new belts which made noise not long after. Put on Continental Elite belts good for over 3 years so far.
Old Jun 23, 2018 | 07:43 AM
Aug Air's Avatar
Aug Air
It was the a/c belt. Thanks for the help!
To Engine squeak
