Over the weekend I attempted to replace my Idler pulley, so I went to auto zone and picked one up. It was slightly different shaped but the same size so I figured no big deal.
WRONG. The replacement doesn’t come with a bolt or washer, and the old Washer does not fit over the replacement properly without totally halting the functionality of the pulley.
so my question is, where are you guys obtaining replacement. Idler pulleys and bolt/washer or at least a direct replacement so I don’t have to replace the washer?
Ive looked around online but I can’t seem to find an exact replacement except on amazon which awkwardly says it’s “not a fit for my 99 Corvette”
just as awkwardly the ones ive found that do look the same all seem to be for 93-96 Corvette? What the crap is that all about?
I believe I got mine at Rock Auto a few years ago when I replaced it...no problems !!!...depending upon how critical of a part I may be replacing I stick to OEM thank you !!...I would never buy a part from Autozone or Pep Boys !!
