Back up lights stay on.
Old Jun 25, 2018 | 12:02 PM
GENE1416's Avatar
GENE1416
1st Gear
Default Back up lights stay on.
I recently got my C 5 out of winter storage. naturally, the battery was dead. Replaced with new battery, but noticed that the backup lights don't turn off. Tried to turn off by removing fuse, but that didn't even work. I removed bulbs as a temporary fix so I don't drain battery, but my PA inspection is due and I think I need the backup lights to be functioning to pass inspection. I know the dealer will charge an arm and leg to diagnose and repair. Any suggestions that I can look for.
Old Jun 25, 2018 | 01:34 PM
grantv's Avatar
grantv
Can't say, but first thing I'd try is disconnect battery for a bit. Old school thinking
Old Jun 27, 2018 | 01:54 AM
striper's Avatar
striper
Reverse light switch just screws into the trans, try replacing it. Maybe it's internally stuck on.
Old Jun 27, 2018 | 02:31 PM
midnight01's Avatar
midnight01
if its an auto trans, there is a switch on the transmission drivers side that connects to the shift linkage, more then likely it needs to be replaced. If its a manual trans there is a screw on switch. I replaced mine because the reverse lights came on in neutral instead of reverse. Check your DIC for codes, it should be
Old Jul 8, 2018 | 06:20 PM
Charles Wanjura's Avatar
Charles Wanjura
2nd Gear
What if the reverse and brake lights stay on then what
To Back up lights stay on.
