Steering Rack Removal HELP
Old Jun 27, 2018 | 11:00 AM
Joshboody's Avatar
Joshboody
Default Steering Rack Removal HELP
So I’m determined to snake the rack out through the passenger side wheel well… since seems this is common method. BUT it seems impossible. I’ve lowered cradle and I don’t see this coming out. Do peeps usually drop the upper a-arm? Is the rack portion outside the car mostly manipulated towards front, rear or up to get it out?
I’ve removed before through the top with radiator out and this is fairly simple... thinking to just do this.
Thanks for any feedback!
Old Jun 27, 2018 | 11:29 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I took the rack out of my car, several years ago, when I replaced the harmonic balancer. I seem to recall that I didn't have any big issues doing this. I had the car on stands, with both front wheels off, and although it was a little "dicey", I was able to work it out without too much trouble....
Old Jun 27, 2018 | 11:56 AM
jonessw20's Avatar
jonessw20
I pulled mine out of the driver side wheel well.
Old Jun 27, 2018 | 11:58 AM
Joshboody's Avatar
Joshboody
When I did my balancer I took it out through the top... half of it out the passenger side then up to fully remove. Sure you got everything through the wheel well then?
Old Jun 27, 2018 | 12:07 PM
Joshboody's Avatar
Joshboody
Thanks, this is how I started but have a flimsy cooling duct that didn't want to remove... and upper a-arm should be disconnected from frame right?
leadfoot4's Avatar
leadfoot4
Yes. "Jonessw20" mentioned that he got his through the LH wheel well, so now I'm not 100% sure which well I worked it out through. As I said, I did this several years ago. However, I DO remember going to the right side first, and I'm pretty sure that I continued in that direction...I know for sure, however, that I did not lift it through the top.
Old Jun 27, 2018 | 12:14 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
That is the way we do it. It helps to have another set of hands to keep the tie rod ends from catching on things.
Old Jun 27, 2018 | 12:32 PM
jonessw20's Avatar
jonessw20
I didn’t remove any of the suspension that I remember. The biggest issue I had was catching on the brake lines and getting the subframe pried down enough to clear. I was gonna try the passenger side but the bulkiest part of the rack is on the driver side. Wasn’t worth trying to snake that all the way across it seemed.
Old Jun 27, 2018 | 12:46 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
Go out the drivers side. Much less distance for the large bits to travel. I've done it a few times and it's come out the drivers side every time without too much fuss.
Old Jun 27, 2018 | 12:52 PM
vettenuts's Avatar
vettenuts
Out the driver's side. Move to passenger's side first and manipulating the tie rod end and manipulate the driver's side tie rod and it came right out.
Old Jun 27, 2018 | 01:06 PM
feeder82's Avatar
feeder82
this is the way i did it also, didn't have to lower the cradle.
Old Jun 27, 2018 | 01:13 PM
DVUSz06's Avatar
DVUSz06
When I did my cam install I removed mine through the drivers side wheel well. I only had to loosen the front two cradle bolts (not rears) and inserted a large flat blade screwdriver between the frame and cradle, two light taps with hammer got me enough room ( no more than .25") to remove the rack. Tapped screwdriver in right beside the mounting bolt.
Old Jun 27, 2018 | 01:54 PM
Joshboody's Avatar
Joshboody
Thanks guys, I'll give it another shot instead of taking the radiator and shroud out.
Old Jun 27, 2018 | 01:59 PM
Joshboody's Avatar
Joshboody
Wow, I wonder if there could be 2 sizes of pinion housings. Currently its hard to imagine possible with the cradle lowered. I was pretty frustrated though, which never helps
Old Jun 27, 2018 | 02:31 PM
feeder82's Avatar
feeder82
It doesn't just come straight out, it's been a while but I remember having to tilt it up the pass. side and twisting it out the drivers side. my radiator and fans were out, only the A.C. condenser was left
Old Jun 27, 2018 | 02:33 PM
pjdbm's Avatar
pjdbm
Drivers side would be easier, I had to go out the passenger side because I had a wall preventing me from bringing it out the drivers.
I had my stabilizer removed, cradle dropped 1/2 to 3/4 had to rotate it constantly to get it out but it did get there with a little bit of patience
Old Jun 27, 2018 | 06:47 PM
Bandit 00C5's Avatar
Bandit 00C5
2023 Corvette of the Year Finalist - Modified
2022 C5 of the Year Winner - Modified
Done this job a bunch. As others have said lower the cradle running the bolts down to the last few threads and inserting large screwdrivers. Make sure to move the EBCM bracket up using the lower holes in the upper holes position. Slide the rack towards the passenger side to get it out of the mounts. Now with a little twisting and a extra set of hands it will go out the drivers side of the car.
Old Jun 27, 2018 | 08:51 PM
Joshboody's Avatar
Joshboody
I got it out... frustration got the best of me last night trying to complete it after work. Knowing it’s possible helps, so thanks for that.
Went thru the pass side, but will try drivers when putting rebuilt unit back in.
Old Jun 30, 2018 | 02:50 AM
Frank O'Brien's Avatar
Frank O'Brien
Drivers side, lower cradle. Watch brake lines .
To Steering Rack Removal HELP
