6th gear?
Old Oct 21, 2002 | 02:45 AM
kluczenk's Avatar
kluczenk
Default 6th gear?
I was wondering if there is a minimum speed I should have the car at before using 6th gear? If I am just cruising around and get up around 50 I will throw it into 6th but the RPMs drop to right at 1 grand.....any reason not to do this?
Old Oct 21, 2002 | 09:33 AM
VetteDrmr's Avatar
VetteDrmr
Default Re: 6th gear? (kluczenk)
As long as the engine is running smooth, no, you won't hurt anything. Of course, you're acceleration from that rpm will remind you of a Yugo. :D
Have a good one,
Mike
Old Oct 21, 2002 | 10:04 AM
Mark VerMurlen's Avatar
Mark VerMurlen
I personally don't use 6th gear unless I'm at 65 mph or higher. I don't like the engine to be below 1500 rpm when I'm asking it for any power. Unless the road is perfectly flat, you'll need some power to climb hills and such. Asking for power at low rpms means you're stressing the engine more than if it was turning more moderate rpms. Just my opinion.
- Mark
Old Oct 21, 2002 | 10:26 AM
VetteDrmr's Avatar
VetteDrmr
Default Re: 6th gear? (Mark VerMurlen)
...Asking for power at low rpms means you're stressing the engine more than if it was turning more moderate rpms...
Mark,
Truly, truly, not wanting to start a flame war, just a quiet discussion, because what you state is a very common opinion, but I haven't been able to back it up, at least for normally aspirated engines.
Detonation and preignition problems aside (which are a problem at whatever rpm they occur), horsepower (how hard we're working the engine) is determined by rpm and torque. When the revs are low, the available horsepower is low (assuming WOT), so the engine demands are low. Also, low rpm have a direct on fuel economy (duh, Mike, when did you figure that one out?) :D. It also reduces engine wear (rings & cylinders, mainly). Charles Lindberg demonstrated to the Army Air Force in WWII that running their aircraft engines (both air and water cooled) at high manifold pressures and low rpm (which gives the same horsepower as lower manifold pressures and higher rpms) resulted in longer range with no adverse effect on the engines.
I've heard that "Well, the bearings take a beating." The only time I've seen bearings significantly worn was in a turbo'ed engine that had been overboosted. Other than that one, all I've seen is just ordinary wear.
Now, acceleration performance is going to be pitiful in 6th, but that's what lower gears are for! :D
So, what'cha think?
Have a good one,
Mike
Old Oct 21, 2002 | 11:04 AM
kluczenk's Avatar
kluczenk
Default Re: 6th gear? (VetteDrmr)
I would tend to agree (although not backing it up with any WWII references :lol: ) and here is why:
The skip shift (1st->4th) will often put you into RPMs of around 1000 and since the engineers put that one in the car I am assuming it should have no adverse effects on the car.....not that I am an engineer (well a computer one but that doesn't count for much here :lol:
Mark,
So, what'cha think?
Have a good one,
Mike
Old Oct 21, 2002 | 12:14 PM
jerryv's Avatar
jerryv
For normal cruising, I'll go to 6th when my speed gets up to 55-60 ..
Old Oct 21, 2002 | 12:36 PM
Mark VerMurlen
Mark,
So, what'cha think?
Have a good one,
Mike
My rationale is that if I am calling for 100 hp from my engine, its going to require less torque at 2000 rpm than it will require at 1000 rpm by a factor of 2. In my mind, less torque means less stress on the engine. The reason that I've picked 100 hp is that you're not likely to be at WOT in 6th gear down at 1000 rpms, but you may need that amount of power for climbing a hill.
I understand the arguement that turning less rpms reduces cylinder wear and so forth. But I also think you need to balance torsional stresses with wear.
I just feel better with keeping my rpms in the 1500 to 2200 range when cruising.
- Mark
Old Oct 21, 2002 | 12:42 PM
Pat97Vette's Avatar
Pat97Vette
I think my manual says not to use 6th gear under 900RPM in that gear. If I have to do under 40MPH, I stay out of 6th. Anything 40 and above, it runs just fine.
Old Oct 21, 2002 | 12:58 PM
VetteDrmr's Avatar
VetteDrmr
- Mark
<keeping the friendly discussion going>
True, torsional loads, like friction loads, do place wear on an engine. But, what we're mainly considering here is highway cruising with slight rises and dips. Sure, when you're going to be climbing a significant incline (or wanting to pass that old geezer in the pretty blue '00 hardtop ;)), you'll want a lower gear. It's just that you want that gear from a performance standpoint rather than a reliability standpoint.
And now consider this (which I'm not claiming as a fact but it seems logical). The harmonic dampener is mounted on our engines to maintain control over the torsional loads that you mention. But, those loads are peaking in the upper rpm ranges, not the lower ranges.
Good discussion for a Monday morning.
Have a good one, :seeya
Mike
Old Oct 21, 2002 | 12:59 PM
VetteDrmr's Avatar
VetteDrmr
Default Re: 6th gear? (Pat97Vette)
900 rpm? Even I don't run mine that low! :lol:
Old Oct 21, 2002 | 01:26 PM
NYtoCA's Avatar
NYtoCA
Wow, i don't go into 6th until i'm at 80 and under most circumstances i have to get back into 5th quickly.
Old Oct 21, 2002 | 01:37 PM
Mark VerMurlen
Mike
Yep, this is a good discussion.
I do some towing with my truck, and I know that often times the truck runs cooler and with better fuel economy at higher rpms than lower rpms at the same speed. So although the rpms are higher, the required torque is lower. As you say, climbing hills or accelerating (or towing) are different than steady state cruising. But you're probably right that I would be fine in my Vette at lower rpms.
One indicator that I use for gear selection is how much throttle input I need when driving. If I find I'm needing to use lots of throttle input to compensate for hills or whatever, I'll select a lower gear that tends to not need so much throttle input.
I'm not exactly sure what your point is regarding the harmonic balancer. My understanding of the harmonic balancer is that it counters some of the transient spikes in torque that occur during fractional rotations of the crankshaft. I really have no idea how it impacts reliability or wear.
- Mark
Old Oct 21, 2002 | 03:02 PM
VetteDrmr's Avatar
VetteDrmr
I do some towing with my truck, and I know that often times the truck runs cooler and with better fuel economy at higher rpms than lower rpms at the same speed...
My experience with towing my ski-boat behind the family's Crown Victoria is similar. In my case, higher octane fuel does the same thing; better mileage and lower temps. That tells me that I'm experiencing some detonation (no knock detection capability, thanks Ford :rolleyes: ). Getting your engine higher up into its torque band and using a better torque multiplying gear will also minimize any detonation problems.
That's the performance "switch" that I was referring to.
Those high frequency pulses are what really works a crankshaft. They impart a lot of energy that has to be absorbed by the crank. As the engine rpms go up, more and more of those pulses start happening in a shorter period of time, until they get close to the resonant frequency of the crank. The rubber (band?, belt? layer?) that's in the harmonic dampener absorbs those high frequency pulses.
Have a good one,
Mike
Old Oct 21, 2002 | 09:52 PM
rg lane's Avatar
rg lane
driving on the back side of the power curve..ie...lugging....is not good for any engine. turbine engines demonstrate this by their slow spool up. the same applies to reciprocating engines. if you want to see if a lower gear is necessary....try monitoring the instant gas mileage and take note at what rpm the mileage is the same(level road) for the lower gear as the higher gear. this is a rule of thumb for driving efficiently(not my priority). when the mileage is the same..shift up. just my opinion. old pilot.
Old Oct 21, 2002 | 10:40 PM
Blue 02 C5's Avatar
Blue 02 C5
If I'm cruising for fuel economy, I shift into 6th for 45 or up, 5th for 30 to 45, 4th for 20 to 30, and so forth.
Old Oct 21, 2002 | 11:09 PM
luvinc5's Avatar
luvinc5
Default Re: 6th gear? (Blue 02 C5)
Wow some of you vette owners shift very early. I like to get to 2k rpm on the gear before upshifting. So that generally means I shift into 6th in the 60-65 mph range.
Old Oct 21, 2002 | 11:23 PM
indyblue98's Avatar
indyblue98
Why not find a stock Vette with the automatic trans and 2.73 gears. See where the GM engineers set the minimum up/down shift points. I would be amazed to see the car shift into the overdrive gear if the engine would be turning less than 1200 rpm after the shift. :crazy:
To 6th gear?
Old Oct 22, 2002 | 04:09 AM
CalHusker's Avatar
CalHusker
I agree with Blue 02 C5 I am on the Highway for the long haul and I live in 6th. I am in it for the economy of course should a need arise to stretch the horse's a bit a quick down shift is required to put the horse's in a more favorable part of the HP/Torque Band. So I cruise at 1500 RPM for days going from Calif. to Nebraska and Back.
Old Oct 22, 2002 | 02:54 PM
mozin's Avatar
mozin
I travel on long trips in my C5. The first months of driving I normally tried to drive for economy but now I tend to drive more for fun, meaning I stay in lower gears longer and enjoy the car more.
55 mph for 6th would be my very minimum speed now but often I will wait for 60mph.
Old Oct 22, 2002 | 03:04 PM
cmacleod's Avatar
cmacleod
Rule of thumb is if you shift into the next gear to soon it's not good for the mains.
This may not be true anymore but that was what I was always told.
:cool:
[Modified by cmacleod, 1:05 PM 10/22/2002]
