6th gear?
Old Oct 22, 2002 | 03:12 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: 6th gear? (kluczenk)
for sustained cruising, I run 6th at 65 MPH with the Cruise control on. I get good mileage too!! :eek: Not bad for a car putting out lots of HP. :)
vetterdstr :cheers:
Old Oct 22, 2002 | 03:24 PM
MRCoupe2002's Avatar
MRCoupe2002
I believe that I read in the owner's manual that you should not shift into 6th until the car is doing at least 50 mph. Unfortunately, since I don't have the manual in front of me right now I can't confirm what page it was on.
My rule of thumb is to shift into 6th around 55/60 and shift back into 5th if my speed drops below 50/55, depending on traffic. Of course I also do a lot of skip shifting from 2nd to 5th, and 3rd or 4th to 6th to preserve gas mileage after a quick squirt of power in traffic.
Old Oct 22, 2002 | 08:18 PM
chocoholic's Avatar
chocoholic
Default Re: 6th gear? (MRCoupe2002)
Actually, what you remembered was the bit in the manual that said for best fuel economy you should shift into sixth at 50 which means you can go into sixth before 50. Of course, the easy answer is just to try it.
Old Oct 22, 2002 | 08:33 PM
Maverick's Avatar
Maverick
Default Re: 6th gear? (vetterdstr)
vetterdstr :cheers:
What he said!!!!! I mainly used 6th gear for fuel economy.
Mav
Old Oct 22, 2002 | 11:27 PM
Denney's Avatar
Denney
Are you telling me that I have a 5th AND 6th gear??? :lol: :lol:
Old Oct 24, 2002 | 08:57 PM
Old Rotor Head's Avatar
Old Rotor Head
Default Re: 6th gear? (Mark VerMurlen)
Same here. 65 and above
Old Oct 24, 2002 | 11:39 PM
MiamiDave's Avatar
MiamiDave
Default Re: 6th gear? (Old Rotor Head)
Wow, I did not know there were other usable gears...I've always redlined first, and than shifted to sixth... :crazy: :crazy:
Old Oct 25, 2002 | 02:40 AM
rrobert22's Avatar
rrobert22
I usually go into sixth gear around 130, keeps me from bogging the engine too much :lol:
