Question?
Old Oct 21, 2002 | 11:15 AM
Smokin Joe's Avatar
Smokin Joe
Default Question about rear end gear change and speedometer
How does changing my rear end gear affect my speedometer reading?
How does changing my tire size affect my speedometer reading?
[Modified by SpyRacing, 4:20 PM 10/21/2002]
Old Oct 21, 2002 | 03:45 PM
SDVette's Avatar
SDVette
2025 C1 of the Year - Unmodified Finalist
2022 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
Default Re: Question about rear end gear change and speedometer (SpyRacing)
I'm not an expert but noticed no one answering your question.
Both will effect your speedometer reading.. I believe both can be corrected in programming in one of the computers.
I'm sure someone will provide more detail.
Old Oct 21, 2002 | 03:50 PM
Mad_Dog's Avatar
Mad_Dog
Cruise-In II Veteran
Cruise-In III Veteran
Rear gear changes will have no effect at all -- I speak from experience. The feed is off the ring gear which is the same size on all C5. I have changed my rear gears and checked before and after using a GPS against the speedometer -- reads exactly the same. The only change you will see is the rpm levels different at the same speed before and after.
Since you have a six speed no re-programming is necessary at all -- just enjoy the improved SOTP performance. :D:D
A4s need reprogramming mainly due to shift points -- but not to correct the speedometer.
Tire size changes (larger or smaller diameter) will affect the speedometer.
[Modified by Mad_Dog, 3:13 PM 10/21/2002]
To Question?
