Thermostat
Old Jul 2, 2018 | 05:19 PM
swampmonster's Avatar
swampmonster
Default Looking to get Water Pump and Tstat. Which should I get?
If I want to replace the thermostat, I can reuse the same housing? I'll I'd need is a new stat and seal correct?
Old Jul 2, 2018 | 07:31 PM
swampmonster
Originally Posted by 8VETTE7
Depends.
There are two different style T'stats that were used on the C5. One is a housing with the T'stat installed in it and the other is a housing and separate T'stat. You need to know which one your car has. It is a function of the water pump itself and the two T'stat setups are not interchangeable if you want the seal to work and not leak:
https://www.corvetteforum.com/forums...d-subject.html
https://www.corvetteforum.com/forums...t-opening.html
Thanks for this heads up!
Old Jul 2, 2018 | 09:34 PM
swampmonster
Depends.
Ok.... so I have a 2004 Coupe and based on my understanding from the above, it should have the new design where the housing and the tstat are not one piece. I also want to get a new water pump because mine is leaking. So i'm also assuming that all the new water pumps are the new design as well. So I should be able to order any new WP and a new tstat and I should be fine using my old housing.
Any recommendations on which WP to get? I am looking at the Gates 45002 or the ACDelco 252-846.
Old Jul 4, 2018 | 02:07 PM
swampmonster
You need to look at what is on your car now. It was not beyond GM to assemble product with what ever parts they had on the shelf at the moment of assembly. PLUS, you have no idea what has happened to the car at the hands of previous owners. A new water pump will NOT come with the housing for the thermostat or the thermostat. NEW pumps will MOST LIKELY be the new design. Remanufactured pumps could be either since there are tens of thousands old design water pump cores out there. If your car DOES have the new design then you can reuse the old T'stat cover if you get a new design pump. If you have the old design pump then you CANNOT reuse the T'stat cover on a new design pump.
Look at the pictures in post #5 of this link:
The first and second picture in post #5 show the NEW DESIGN T'stat cover and T'stat. The 3rd picture shows the old design T'stat cover and integrated T'stat. Very visible differences. So figure out what you have on your car so you know whether you will need to order a T'stat cover for your replacement water pump.
I have no preference of brand for a replacement pump.
Thanks again! I looked under the hood and I have the new design Tstat cover... it doesn't have that hook thing.
Old Jul 15, 2018 | 06:12 PM
swampmonster
So I finally got the chance to replace the pump today. I also replaced the AC belt while it was easy to do so. Waiting to get the serpentine belt in the mail to put that on.
Regarding the pump, what a pain to get the old red gaskets off. That thing was on there like no ones business! I had to scrape that thing off. I also noticed that in the process I put some scratches on the aluminum. I got some sand paper and filed it down a bit. Hopefully the new gaskets will seal well... I'm a bit anxious about it (how worried do I need to be here?). I used rubber bands to keep the gaskets and screws in place while wiggling the new pump in position. Then just cranked those screwed down tight.
As soon as I get the new belt I'll put that on and refill the cooling system with water and see if I have any leaks. If no leaks after a few days I will flush and put new coolant.
Old Jul 15, 2018 | 06:50 PM
swampmonster
As long as they were scratches and not deep gouges you should have no problem................
Ok thanks! I ran my finger nail over them after sand paper and was barely able to feel anything.
Old Jul 27, 2018 | 02:22 AM
swampmonster
The new water pump seems to be holding up well so far, I am very happy and greatful for all the help!
I am paranoid about one thing though. I didn't use a torque wrench when I fasened done the pump. I'm worried that I over torqued the screws. I didn't put all my weight into them but I did use some force. I didn't feel anything funny though. How concerned do I need to be?
Old Jul 27, 2018 | 07:19 AM
crf450x's Avatar
crf450x
You don't. I've never used a torque wrench for water pump bolts. Going by feel is good enough for that.
To Thermostat
