2001 c5 front transmission leak
Thank you all for any help you can share my way.
Well Sir, Thank you very much for you valued information even though it nots quite what i wanted to hear I ask for the truth and you gave it to me. Haha Dang why can anything ever be easy Im find out on one of the cars cause of everything so hard to get too. Oh after i put this post out there for help i actually did find a post where someone had taken a picture of the same place my little leak is hanging under the front case at. I also noticed the weep hole up the side of the case a little and nothing is coming out that weep hole so leak may not be really bad right now. This man was talking about cleaning the area really good with brake clean and then using silicone to run along the bottom of that case to stop the fluid from reaching the ground. At least i would'nt notice the small stop on the carport floor maybe for a while till i find someone i trust enough to pull all that unit out of the car.
Thank you all you fine folk for your answers and at 59 years old and having many hotrods and older cars in the past like i said this is my first vette and i love it.
Trans fluid on the garage floor, not much but still.
I thought it was the output shaft seal but I got under there just now and no, it looks like it's coming from the front of the trans. 1 drip forming on the bottom of the pan
You can't just pull the input shaft, the driveshaft ??
There is a differential and there is a Transmission bolted to the front of the differential.
I was just under there and I did not identify each one or exactly where the leak is coming from except to see that it is not leaking at the differential output shafts, the leak is more centered and more forward of that. The drip I noticed looked like it was at the front of a sheet metal pan. I'm now thinking that this is a Transmission leak of some type.
I have an auto trans.
I was under there and the neighbor came over and started talking to me so I got distracted. He was saying that he hoped I hadn't been under there all night so I felt I had to get out just so he didn't call the fire dept. or something ... lol
Im glad you wrote me about what yours is doing just like mine, now this is only after talking to two different people. One being My regular Tech at the shop and One man being a long time Transmission shop owner that know the cars very well both told me the same thing, If fluid is not coming out of the weep hole it is most like not the front pump seal leaking but like you said most likely the Transmission pan itself seeping a little which is pretty common i understand. I drove the thing this weekend and parked it yesterday and it has "not" leaked a drop so Ill feeling pretty good about it being the pan gasket. We will see.
Oh while i was talking to the man at the transmission shop i again ask him about what kinda cost to fix the seal if it is it, He laughed a little and said "Jeff" our guys can pull that whole underneath of that rear end in about 45 minutes and change that seal and have fluid back in it and serviced in about two hours. Now the bad part is the labor book says this is a 8 hour job and thats what i can expect to pay for, doesnt seem quite fair does it but that how the Techs at the shops make there money. I told him i liked his honesty and i just hope all i have is a slight leak on the pan gasket every now and then. Thanks all you fine people will let yall know.
But then again I have never changed the Transmission fluid since I've owned the car, 12 years now, so maybe it's time ??
I still havent taken mine to him yet so I still dont know if any of what im writing here is actually the case, Im going too a car show this weekend and Ill be back out riding in it for a while and when I bring it back home Im going to see if its leaking anything after that. Please let me know if you get yours looked at before I do or if i get this one checked before you I will let you know.
