Clutch Adjustment??
Old Jul 6, 2018 | 05:53 PM
VETTEC599's Avatar
VETTEC599
Default Clutch Adjustment??
I am unfamiliar with C5 clutches - is there a way to “adjust” them? Mine catches near the top of the pedal travel. This is my DD. I am drive it a spirited manner; however, no clutch dumping, power shifts, etc. There is no hesitation going gear to gear, no grinding of gears. I ask because it is annoying!
Assuming that the time has come to be proactive - along with the clutch and pressure plate - what more should I include to make it a onetime job? Suggestion as to brand? I plan to keep the Vette! Thank you in advance,
Old Jul 6, 2018 | 10:43 PM
ForceFedC4's Avatar
ForceFedC4
Take a look at the color of the hydraulic fluid in your clutch master cylinder reservoir. If it's black as night, which it likely is.. you may want to consider replacing the clutch master cylinder (easy to do) while you are at it. Definitely the slave cylinder while you are doing the clutch / pressure plate / flywheel (resurface or replace.)
