98 ls1
Old Jul 8, 2018 | 01:16 PM
Krazykajun's Avatar
Krazykajun
2nd Gear
Default 98 ls1
Thru the drive belt,replacing with as new 1 but it seems real loose.
is this common?
Old Jul 8, 2018 | 01:59 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Welcome to the forum!
Sorry - not sure I understand your question, but lots of great members and helpful info in the C5 section of the forum at https://www.corvetteforum.com/forums...s-1997-2004-2/.
You probably should post your question (with a little more info), in the Tech section.
Best wishes with an easy resolution to your problem.
Old Jul 8, 2018 | 06:55 PM
jehuds10's Avatar
jehuds10
Old Jul 8, 2018 | 08:25 PM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
Check in with the folks on the C5 forum. Good luck and welcome!
Old Jul 8, 2018 | 10:03 PM
Moved over to C5 Tech.
Old Jul 9, 2018 | 12:01 PM
Krazykajun's Avatar
Krazykajun
2nd Gear
Default Thanks
Yes it is the correct belt..
I recently was informed that with the early c5 a lot of folks were having this problem because the belt was slipping off the grooves..I was told that they came up with a fast simple solution but I can't locate that thread...any help would be greatly appreciated
Old Jul 10, 2018 | 03:38 AM
sirdano's Avatar
sirdano
Wondering if your harmonic balancer is bad? You said it was slipping off grooves. Does it wobble? Is it moving front of back?
To 98 ls1
