2004 Fuel Pressure Regulator
Old Jul 16, 2018 | 09:10 PM
Classic-Chevy-Guy's Avatar
Classic-Chevy-Guy
Default 2004 Fuel Pressure Regulator
A friend’s 2004 C5 with 120k Miles is getting a CEL and a code which indicates a bad fuel pressure regulator.
What is the procedure and average cost to replace?
Any easy remedies to try first like Techron?
Thanks for the assistance.
Old Jul 16, 2018 | 11:47 PM
Classic-Chevy-Guy
Code P0446 indicates a fault in the Evaporative Emission System Vent Control electrical circuit for a predetermined period of time.
Old Jul 17, 2018 | 12:22 AM
Moved to C5 Tech.
Old Jul 17, 2018 | 10:39 AM
Classic-Chevy-Guy
Thanks for your assistance. I am in the middle with my friend, so I am just relaying the info that he provides.
Would appreciate the diagnostic tree from the Shop Manual.
Thanks for the help.
Old Jul 17, 2018 | 10:52 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Being that this is an electrical issue do you have or are you good with a multimeter ??...if not best to bring it to a shop...save yourself money in the long run not shotgunning parts !!...would have to look at the diagnostics for this but you MIGHT need a smoke machine for this DTC !!
Old Jul 17, 2018 | 10:54 AM
Classic-Chevy-Guy
Thanks. I have a multimeter and a lift.
Will start the diagnostics tics with the tree.
Old Jul 17, 2018 | 11:17 AM
C5 Diag's Avatar
C5 Diag
GREAT !!...I HATE those flowcharts !!...if you have some knowledge on how the system operates you really don’t have to use one...GOOD LUCK...keep us advised ??
Old Jul 17, 2018 | 10:05 PM
Classic-Chevy-Guy
Thanks a bunch. Will post the solution.
Old Aug 9, 2018 | 06:04 PM
Classic-Chevy-Guy
Dealer replaced the vapor relief valve. Solved the problem.
Thanks to everyone who assisted above.
Old Aug 15, 2018 | 11:54 PM
Classic-Chevy-Guy
Update to the Update.
After the Vapor Relief Valve was replaced, the Check Engine Light continued to be illuminated.
The dealer then replaced the Fuel Tank Pressure Sensor and the Jumper Harness.
That solve the CEL.
To 2004 Fuel Pressure Regulator
