Clutch problem
Old Jul 17, 2018 | 05:16 PM
Dan Fandrich's Avatar
Dan Fandrich
Default Clutch problem
I just bought a 99 C5 with 32000 miles. The Clutch peddle of the car intermittently stays all the way to the floor. If I pull it back up it works for a wile but eventually sticks to the floor again.
any ideas why and what it will take to fix it.
Old Jul 17, 2018 | 05:43 PM
99blkfrc99's Avatar
99blkfrc99
many many documented threads on this. Lots of info out there. What worked for me was an aftermarket clutch with new slave.
Old Jul 17, 2018 | 05:54 PM
001pewter's Avatar
001pewter
St.. Jude Donor '17-'18
Sounds like the clutch master cylinder, not hard to change but the quick disconnect can be a pain to get apaart.
Old Jul 17, 2018 | 06:18 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Old Jul 18, 2018 | 12:59 AM
Moved to C5 Tech.
Old Jul 18, 2018 | 03:05 AM
NSFW's Avatar
NSFW
I had the same problem, did a bunch of reading, started a thread to try to figure out exactly what's going on, wasn't satisfied with the answers, decided to replace the master and slave cylinders, throw-out bearing, and the clutch all at once, and add a remote slave bleeder too. (And a pilot bearing, because it'll never be easier to replace. And check the torque tube bearings and couplers whlie everything is apart.) The clutch just arrived, installation is in two weeks.
Here's that thread - I added some links to other threads that shed some light on the problem:
https://www.corvetteforum.com/forums...the-floor.html
As far as I can tell, the one thing that consistently fixes it is replacing the OEM clutch for an aftermarket clutch. Apparently, pretty much any aftermarket clutch will solve the problem. And as long as the drivetrain is coming out for a clutch swap, I figure I might as well replace everydamnthing else too.
Old Jul 20, 2018 | 12:17 AM
Leenorm1's Avatar
Leenorm1
I have not changed any parts but have had same problem in the past and am satisfied with vacuum bleeding and the ranger method.
Old Jul 20, 2018 | 10:26 AM
huesmann's Avatar
huesmann
How do you know that a new OEM clutch wouldn't also solve the problem? Or that it's not just the PB/TOB/MC/SC that are the real solution to the problem?
Old Jul 20, 2018 | 07:26 PM
rock_man's Avatar
rock_man
I've read reports of the Tick clutch master cylinder upgrade fixing a lot of our clutch issues.
https://www.tickperformance.com/tick...rvette-c5-z06/
Much cheaper (even including the GM quick disconnect tool) than a drive line drop to replace other parts. You could try it first? Good luck!
Old Jul 21, 2018 | 12:46 AM
NSFW's Avatar
NSFW
If it only cost $20 to swap each part (or heck, $50) then I'd probably swap parts one at a time. But replacing most of those parts (other than the MC) require dropping the drivetrain, so trying one at a time could be a very long / expensive / time-consuming proposition. (Which is probably why the problem is still so poorly understood.)
Also, I want to drive this car, not troubleshoot it work on it. I bought it for track days, and I've had my fill of wrenching on cars in the pits, so I'm doing all of the preventative maintenance that I can think of.
That said, replacing the master cylinder as a first step is not a bad idea. It's one of the least expensive things you can try, after removing the pedal spring of course.
To Clutch problem
