How to remove automatic gear shift knob?
Ken
I see no retaining clips. Does this just unscrew?
In my case, the bushing on the console's end of the cable was the one that disintegrated, but I replaced the bushings on both ends for peace of mind. I'm glad I did because the one on the transmission's end disintegrated in my hands just by looking at it
It's true that one have to be careful not to bend this cable too much, but what you can safely flex it, is enough to replace the bushing. I took these pictures when I replaced mine:
After inserting the new bushing:
As mentioned above, even though at this point most probably only 1 gave up, take the opportunity and replace bushings at both ends.
All you need is the kit ($12 and free 2-day Prime shipping from Amazon). Use the white bushings (the orange ones are for Ford):
And
This is very doable and it's just a few bucks and a couple of hours to change the bushing at both ends of the cable, taking your time
Correct replacement bushings?... Not so sure. The OEM ones do not have any splitting cut to facilitate installation, which could also compromise safety and a long lasting repair.
Hope they continue to hold tight.
OEM / Dorman:
Eckler's:
