Odd TCS Error happening
Old Jul 31, 2018 | 08:26 PM
mre1974's Avatar
mre1974
Default Odd TCS Error happening
Recently I have been experiencing an intermittent condition where I will be driving and usually it has happened on a long gradual curve where the "ACTIVE HANDLING" warning will flash on the DIC the car will vibrate and cut power then the TCS light will stay on and I get the "SERVICE TCS" warning.
This also happened when driving in a straight line once before.
Stop the car, turn off, let set 10 to 30 sec, turn on, start, no error.
A couple of times I have put the TCS into "COMPETITIVE DRIVING" mode and I don't get the ACTIVE HANDLING warning...which makes sense since it's turned off.
Error codes pulled from DIC are:
C1225 H
C1281 H
C2100 HC
C2105 HC
C2115 HC
I know that the last 3 are related to the TPMS they have been dead for years and usually I just clear them and no issues.
This past weekend I did a full trans and diff flush and fill (correct fluids and fill levels).
Replaced shocks on all 4 corners (Johnny O'Connell Stage 1 shocks...AWESOME so far)
Rear tires are almost at the wear bars but still have tread...not bald.
Thinking I'll go ahead and put tires on the rear ASAP but still wanted to bounce this situation off other members to see if you may have other suggestions to check.
Thanks in advance.
Old Jul 31, 2018 | 10:45 PM
Moved to C5 Tech.
Old Aug 1, 2018 | 07:48 AM
mre1974's Avatar
mre1974
Thanks 8vette7. I'll have to remember to pull over and pull the codes BEFORE shutting down next time it happens.
IF it does turn out to be the SWPS it looks like I'm going to have a hard time finding a replacement and that they aren't cheap.
Can they be 'repaired' or do you pretty much have to replace them when/if they go bad?
Old Aug 2, 2018 | 11:02 AM
mre1974's Avatar
mre1974
Thanks for the help and links 8vette7. This weekend I'll have to pull the wheels and check the connectors from the first reply and maybe check the SWPS while I'm at it.
Hopefully I can get it all sorted out as currently my FRC is my daily driver and I have a 180 mile daily round trip commute. Kinda need to keep all things sorted out.
Old Aug 2, 2018 | 01:06 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Before you get too far into the system, the EBTCM MUST have sufficient supply voltages and a proper ground for the module to work properly. Recommend that you check the test slots on top of all EBTCM fuses to a good chassis ground Especially Under hood fuse box Fuse #5 ABSTRANS 10 amp. That fuse is supplied by the ignition switch and the voltage at that fuse can be LOW! Make SURE that the motor lug ground and where it attached to the chassis is 100%
Old Aug 6, 2018 | 02:15 PM
01Vette27's Avatar
01Vette27
8th Gear
Hello,
I have a 2001 Coupe, I get the error code C1225 when ever I do a quick acceleration up to 100 MPH. Cleared the code and did another run. Same thing happened at exactly 100 MPH. Went home, pulled the left front wheel and inspected the sensor wire harness and both ends of the female connectors. All were clean and it proper position. I know the previous owner had the EBTCM repaired. Any idea's? Probably shouldn't worry about it since everything is fine under normal speeds.
Old Aug 7, 2018 | 01:35 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
LOL!! Your are NOT alone with this issue but, one of only a FEW who ever expierence it. Mine would error out at 47 mph and I had another forum member who would error out at 103. The only solution is a new EBTCM. Been there done that. Paid the $$$$$$$$$$$$$$$$$ for the new EBTCM.
Bill
Old Aug 8, 2018 | 08:44 AM
01Vette27's Avatar
01Vette27
8th Gear
Thanks for confirming, Bill.
I guess I will have to let off the gas pedal before 100 MPH to avoid the annoying check engine light. Ha Ha.
I am glad that I won't have to bother trying to find the issue or replace any parts. The previous owner did pull the EBTCM back in 2013 and had it repaired by ABSFixer in Highlandville MO. 877-648-7530
I called them and they confirmed that the repair is not always 100%. In other words, it's repaired for normal driving conditions. The repair cost $215.50
Old Aug 8, 2018 | 01:13 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
ABS Fixer can fix some of the ILLs in the EBTCM. However,,,,,,,,,,,,,, They can NOT do ANYTHING to repair the small micro processor board deep in the bowls of the unit. Its VERY PROPRITORY and potted in that clear goop stuff that protects the board and the components. That error has everything to do with a problem inside the micro processor.
Bill
Old Sep 6, 2018 | 04:45 PM
mre1974's Avatar
mre1974
Well, after almost a month and a half and 3500+ miles it happened again.
Pulled over and pulled the following codes before turning off the car.
TCS - C1281 C
BCM - B2723 H
BO-RFA - C2100 H
C2105 HC
C2115 HC
Sure is a bit unsettling when you're driving along and suddenly power cuts and the DIC warning pops up.
Old Sep 6, 2018 | 06:08 PM
mre1974's Avatar
mre1974
Originally Posted by 8VETTE7
Code meanings above in RED.
Steering Wheel Position Sensor is on its way out. What you felt is the AH system trying to step in because of erroneous input from the SWPS. Replace the SWPS.
The pass Key error is probably because the pellet on your key is dirty and from time to time it gets read incorrectly. I would switch off to your backup key or clean both the key pellet and the reader contact that reads the key. It is located inside the key cylinder.
The RFA errors are telling you that the specified TPMS are not reporting in. If the TPMS are of unknown age it is probably time to replace all 4.
I figured that the SWPS was going from the previous responses...SIGH. Not something I can afford right now but may be stuck addressing.
I get the key errors off and on...it comes and goes. I almost wonder if it's that the tumbler cavity in the key cylinder needs to be replaced. I have noticed that I can actually remove the key from the ignition and the car keep running. LOL
Yeah, the TPMS sensors are bad. I know that two are dead and the other two work intermittently.
The SWPS is the one I am most concerned about especially due to cost of replacement.
Old Sep 8, 2018 | 10:49 AM
Bill Dearborn's Avatar
Bill Dearborn
OP: How is your wheel alignment? If the steering wheel is off center while driving the car down a straight road this code can be set. If the car pulls one way or the other this code can be set. Once the offset of the steering wheel exceeds a certain angle from 0 (0 being straight ahead) the EBCM can interpret that turn as an error in the steering sensor. You may need nothing more than a good wheel alignment.
Bill
Old Sep 13, 2018 | 03:40 PM
mre1974's Avatar
mre1974
Bill
Thanks Bill. Now that you mention that my alignment does seem to be off slightly after removing and upgrading my old C6Z06 shocks to the Johnny O'Connell ones for the C5 & C6. I have not had a chance to get it into a shop to have it checked yet. I'll need to do this ASAP. Heck, if that resolves it that would be great. I have looked high and low and can't find a new/replacement SWPS for my '99 anywhere right now.
To Odd TCS Error happening
