Rear Main Seal
Old Aug 4, 2018 | 01:24 PM
VetteMan2012's Avatar
VetteMan2012
Default Rear Main Seal
I have oil under my car. Getting worse and I noticed the oil filter is soaked and some oil sitting directly under the where the trans and engine meet. Nothing on passengers side. Rear main seal the culprit?
Old Aug 4, 2018 | 02:20 PM
Smoken1's Avatar
Smoken1
I would look up higher behind the intake manifold. The oil pressure sending units are prone to leak.
Old Aug 4, 2018 | 06:56 PM
Spaceme1117's Avatar
Spaceme1117
Could be a rear main seal.
But as Smoken1 stated, it could be the are where the oil pressure sending unit is. I had a 2006 GTO that had an oil leak at that exact area. I changed the valley pan gasket and sure enough, no more leak.
Old Aug 4, 2018 | 07:01 PM
StingrayRebel's Avatar
StingrayRebel
start up top and work your way down... if you don't have headers you can easily unbolt the inspection cover (if you have one) and get a better look... fyi the trans is in the back of the car, it doesn't bolt to the engine
To Rear Main Seal
