Hvac help
Old Aug 8, 2018 | 10:50 PM
CASEWORER's Avatar
CASEWORER
Default Hvac help
AC is acting up. When the car is at idle car blows nice cool air from both drivers side vent and passenger side vent. When I start driving down the road the drivers side warms up a little not hot but definitely not as cool, while the passenger side stays nice and cool. When I return to a Idle both sides are nice and cool what is going on here ? Have history codes of 361, 367. I have not checked the Freon level this year since the whole AC system was replaced last year but plan on checking it this week hopefully. I found one other post on the net with this same problem but no resolution. I figure with the depth of Knowledge on this forum someone has to have had the same problem and knows how to fix it. Thanks Guys.
Old Aug 9, 2018 | 10:55 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Sounds very much like you have a low charge. The only way to confirm that is with a set of gages (charge manifold)
BC
Old Aug 9, 2018 | 10:01 PM
CASEWORER's Avatar
CASEWORER
BC
Thanks Bill I was going to PM you if someone didn't respond. After I check the charge level I will report back. I am hoping that is all it is.
Old Aug 10, 2018 | 10:21 PM
CASEWORER's Avatar
CASEWORER
BC
Checked Freon level today. Sure enough it was a little low.
Old Aug 11, 2018 | 06:37 PM
SG Lou's Avatar
SG Lou
That will do it, Glad it was an easy fix for ya !
To Hvac help
