Dash/Gauge lights not working with headlights on
JUST MAKE SURE THAT YOU DONT LEAVE IT IN THE FULLY CW POSITION.
The C5 has so many lights schemes that are BCM controlled, multifunction switch controlled, ect that its difficult to decipher someone's problems sometimes only because they don't accurately relay exactly what is happening or don't see all of the lighting issues.
SO, that being said, I would look at the multifunction switch.
NOTE! The actual gage face and gage needles are NOT back lighted. They are reflective lighted by BLACK LIGHT Florescent tubes in the LEFT and RIGHT corners of the IPC that accent dayglow painted objects.
BC
BC
The IPC can be LIGHTED two ways. The BCM can turn on the lights (as when you unlock the car with the FOB) OR You can turn the multifunction switch to make lights come on. IF the BCM can light the IPS but the multifunction switch can,, THAT a multifunction switch issue. See if you have hazards, and see if the light turn on with the BCM circuit
There are TWO fuses that you need to check: In the late model cars 01-04 its:
HAZT/SG fuse #15 20 amp & STP/HAZ fuze#8 20 amp.
Don't know the FUSE numbers for your fuse box They are in the passengers foot well fuse box.
Bill
Bill
