Fuse Tap
Old Aug 13, 2018 | 05:47 PM
nivensid's Avatar
nivensid
Default Fuse Tap
2000 coupe. I have a Backvue Dash Cam to install. I need to tap into the fuse box for a circuit that is continually hot with ignition off and another circuit that is ignition switch hot. Can someone identify the fuse numbers? I am at work now trying to plan the install. Thanks
Old Aug 13, 2018 | 05:52 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
https://www.corvetteforum.com/forums...post1586315785
Old Aug 13, 2018 | 06:08 PM
nivensid's Avatar
nivensid
thanks
Old Aug 13, 2018 | 07:39 PM
Tsumi's Avatar
Tsumi
Since you have a 2000 Corvette, look in the passenger footwell. There should be three wires there above the BCM on the left side. Link to picture along with instructions: https://www.corvetteforum.com/forums...post1571594201
To Fuse Tap
