Help me out vette tech
Old Aug 15, 2018 | 09:55 AM
Lt1slowerbird's Avatar
Lt1slowerbird
Default Help me out vette tech
I have a 2000 ws6.
235/243 .630/.610
PRC 225 heads
ls6 intake w/ 42lb injectors
I’ve posted on ls1 tech and got not too much info.
Heres copy of my post
Long story short I have an mpvi2 that is on way back to hptuners. Fairly certain unit is defective. However here is what happened. The unit was having issues connecting. I figured it was my side of things so I uninstalled and re installed software.
I reflashed car after making some adjustments to throttle cracker and as it was writing and doing its thing I washed the car. I open the door and it was done. I start the car and immediate very high idle. Like entire brake booster hose was off. 3000rpm. I was like oh man. I pulled car into garage and thought maybe this unit is going bad. I tried to do a reflash but unchecked the high speed write. It started to erase and failed mid erase and car wouldn’t start. After about a dozen controller unlocker errors I wound up disconnecting the battery and opening vcm editor from original folder and it finally reflashed. The high idle is stuck there and I start trouble shooting this. Iac valve is fully retracted and it will do nothing but vibrate when I command different counts in the scanner. Even a new ac delco will do nothing. If I manually pull out iac valve and disconnect and reinstall the car idles fine once I get it close to adjusted for set rpm. I’m almost certain it’s not a mechanical issue but a software/electronic fault. I hooked up the mpvi2 to laptop today and it won’t even recognize. In the mean time has anyone had this happen? Should I go ripping into the iac harness or do you think a clean write with a will fix this? This is incredibly frustrating and stressful so I guess I’m just fishing for someone else’s experiences and solutions. Also considered bad pcm or iac drivers? Connectors on pcm harness are red/blue.
i have checked for continuity for iac harness to pcm and all was good
Also if I have iac set close and plug in iac while car is running good it will slowly retract the pintle valve until all the way retracted causing a massive amount of air and an idle of about 2500-3000 rpm
Old Aug 16, 2018 | 01:25 AM
Lt1slowerbird
Bump? anyone have any thoughts on this?
Old Aug 16, 2018 | 02:24 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
What does your “IAC position” reading on your scan tool ??... 0 perhaps ??...should be around 30 or so at idle. What are your long and short term fuel trims looking like at idle ??...have you clamped off the brake booster hose to see if there is an internal leak in the brake booster and your IAC counts go back to normal and the RPM’s come down ??
Old Aug 16, 2018 | 02:33 AM
Lt1slowerbird
I cannot verify atm as scanner is at hptuners. If I recall it made no attempt to lower idle however set the po507 code. Shut car off and iac valve was completely retracted every time. Was the same position even when unplugged during motor operating Incase pcm sets iac to “park” position at shutdown. The only thing is the iac valve is not opening at all. At 0 steps it should be extending to shut down airflow but it’s not. The motor receives signal as you can feel it vibrate and see pintle vibrate but it doesn’t move outwards. Like it’s getting a command to retract even though it’s already fully retracted. However if I manually set iac to completely close off it will not run without throttle. So once you set it to about where it needs to be it will run and idle perfectly until you plug in iac. Before issue I had iac counts to about 50-60 at 210 hot idle fans off tps voltage was .67 via hptuner reading. Also when I set iac manually my shorts are around -1 to -4 and I am not using long terms
Old Aug 16, 2018 | 03:33 AM
C5 Diag's Avatar
C5 Diag
How did you check the IAC harness electrically??...it’s “ground side switched” at the PCM so if it’s a 4 wire stepper motor you would connect a 12 volt test light to battery POSITIVE and with the harness unplugged touch each of the 4 wires and the test light should flash as the engine is revved !!...if no flash either a wiring issue or bad PCM...have you done that??...I was asking about the long terms because if they were way positive we might have a vacuum leak...an 0507 isn’t always a bad IAC...something else is causing the high idle like a big vacuum leak !!
Old Aug 16, 2018 | 03:57 AM
Lt1slowerbird
I simply tested for continuity from each lead to the respective Pinout for the pcm. And I checked operation by commanding it to extend or retract via vcm scanner special controls. I have no idea what the issue is. It’s not the iac valve. It operates exactly the same be it a 40 dollar bwd valve or an 80s dollar AC Delco. Both give me the same result and when plugged the car dies. But set right and then disconnected car runs fine. Revs up and comes right back down to idle. And I’m pretty certain there is no vac leak as the issue is 100% resolved when manually setting the iac. Plus for 3000+rpms id think the vac leak would be huge. Car has new pcv and is fairly new topend build. Intake has new gaskets and is torqued to I think a touch over spec. Like 95in lb
Old Aug 16, 2018 | 04:11 AM
Lt1slowerbird
This is the diagram correct? I think i read for a lt1 they should ohm like 40-80 between A-B/ C-D I cant see ls1s being much different correct?
Old Aug 16, 2018 | 04:55 AM
C5 Diag's Avatar
C5 Diag
No IAC on the C5 Corvette !!
Old Aug 16, 2018 | 05:08 AM
Lt1slowerbird
Old Aug 16, 2018 | 05:30 AM
C5 Diag's Avatar
C5 Diag
Originally Posted by Lt1slowerbird
I usually won’t touch a “tuned” car, I’d tell the owner to take it back to the tuner !!...you have to know circuit design to troubleshoot the circuit (I bet you followed the FSM flow chart)...a continuity test won’t tell you everything !!...you have to make sure you don’t have an “open coil”, “shorted control wire”, or “shorted PCM driver”... that’s about it for this circuit design !!...being that this circuit is ground side switched with the key on the test light should illuminate when touched to the control wire...turn the key on and off a few times and the light will come on and go out...well, that’s about it Bubba !!
Old Aug 16, 2018 | 07:29 AM
Lt1slowerbird
Continuity from harness to pin leaves the rest of those instances being a pcm error correct? I’m not sure what you mean by control wire? Is there a wiring diagram of iac that I’m not aware of? Please do elaborate. I’m not a very Adept Tuner and the electrical nightmare is not my strong point.
Old Aug 16, 2018 | 08:36 AM
C5 Diag's Avatar
C5 Diag
No No, No !!..Like I said you have to make sure that the PCM driver is grounding all of the 4 wires (control wires) when the key is turned on...continuity test will not show this... now some IAC's have a separate fuse to power the IAC motor...these would be a 6 wire design ( a power wire for each coil) which Nissan's come to mind. Those GM 4 wires are powered internally in the PCM...a wiring diagram doesn't really show this....like I said 12 volt test light connected to battery POSITIVE.... touch each of the 4 control wire while cycling key on and off...test light should illuminate (the driver is grounding the circuit hence the test light comes on)...to be honest if your electrical skills are not that good I would say bring it to a reputable shop !!...now you said you changed the motor with an AC Delco...what are the resistance readings between the old and new ??
Old Aug 16, 2018 | 08:49 AM
Lt1slowerbird
So if I have continuity on wires to harness then the wiring is good and pcm may be at fault correct? I am thinking when I had a failed erase on my programmer it corrupted my iac drivers. I know it’s not the IAC Motor itself. This has been 2 new iac motors after the original which I honestly think is still good. I will try to get a test light and test that if my lead is long enough
Old Aug 16, 2018 | 09:06 AM
C5 Diag's Avatar
C5 Diag
If test light lights it's telling you that the PCM driver is grounding the control wire and working as it should...light on...wiring good...I NEVER replace a part like this without checking power and grounds...unfortunately I see a lot of this here...you can change 100 IAC motors but if the wiring is bad you're not going to fix it !!....like I had mentioned I don't mess with these tuned cars !!
Old Aug 16, 2018 | 09:54 AM
Lt1slowerbird
Yes I understand however the issue never happened before the failed write. I had a bit of idle hang but my throttle cracker tables needed a slight tweak. I don’t think it’s my wiring. I have continuity to the pcm pinout so that means each lead is not broken correct?. So they should work and be able to transfer power. Unless I don’t understand continuity. Lol. I think my pcm is the issue. After the failed write the car wouldn’t start and gauges went stupid bouncing from left to right. A reflash let the car start but ever since the iac idle control has been messed up. Coincidentally the thing I was changing in the tune was the throttle cracker which is directly related to the IAC. I know it’s getting power because when I commanded steps The motor would vibrate . Just the pintle would not move in the proper direction it seemed it only tried to retract. Even at 0 counts which should be fully extended. Which is why I checked for continuity wire by wire thinking I may have rubbed through and be jumping leads but I think I’ve corrupted the iac drivers and it may just need a write entire tune.
My end theory is my wiring is good by continuity check. Iac circuitry is a closed circuit when manually operated with a scanner and I either f’d the pcm by the failed write or I corrupted some driver files in the software. See what I’m saying? I’m off this weekend and will find my test light at the shop
Old Aug 16, 2018 | 10:24 AM
C5 Diag's Avatar
C5 Diag
I know nothing of this throttle cracker tables...is it like a Ritz cracker ??...LOL !!...like I said power is waiting to get "grounded" by the PCM driver for the coils to be powered through the control wires...you should probably school yourself on "ground side switched" circuits..your fuel injectors work the same way...that's how you check injector control wires !!...well do what you have to do with your reflash !!
Old Aug 16, 2018 | 10:33 AM
Lt1slowerbird
I believe all vettes were drive by wire. Trans ams and Camaro got drive by cable until I think 01 or 02?? I might be wrong. Anyway to control idle airflow the cable driven throttle bodies have an iac valve to let bypass air. The throttle cracker table is an airflow ADDER that allows airflow past when you close throttle plate. It slows rpm drop to help with shifting but it’s main cause is that without it some cars will overshoot idle rpm and bog or even stall. It’s like a cushion to allow a more controlled rpm drop. Too much “cushion” and idle will hang from too much air
To Help me out vette tech
Old Aug 16, 2018 | 11:02 AM
C5 Diag's Avatar
C5 Diag
Yes, my 2001 is drive by wire...it uses various inputs from the PCM to control idle speed. We have a TAC (Throttle Actuator Control) module which sends a signal to the TAC motor located on the TB to control idle speed by opening/closing the throttle plate !!
Old Aug 16, 2018 | 07:51 PM
Lt1slowerbird
I wish I had that to tell you the truth lol.
Old Aug 16, 2018 | 07:59 PM
C5 Diag's Avatar
C5 Diag
IAC...TAC...tomato, tomatoe...it’s all good !!
