Camshaft recomendations 2001 LS1 A4
Old Oct 23, 2002 | 03:14 PM
wm_sorg's Avatar
wm_sorg
Default Camshaft recomendations 2001 LS1 A4
I was thinking of using the GM LS1 hot cam. How much HP will thi give me?
Otherwise, can someone recomend a good alternative. Car is a daily driver, A4. Needs to idle smooth and pass VA emissions.
Thanks,
BILL
Old Oct 23, 2002 | 04:51 PM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
Default Re: Camshaft recomendations 2001 LS1 A4 (wm_sorg)
Thanks,
BILL
My advice, do it once, do it right! Do some research and pick the one you really want. The hotcam will not be your best choice for an A4.
I would recommend the B1 cam or one of the Thunder Racing cams(224 114LSA is a good one). There are several guys making good #'s with these. I made 375rwhp in my M6 w/ no tuning using the B1 cam before I took it out. Try to pick a cam with a 114LSA to help idle out some by moving the peak up the rpm range.
Here is a link of someone who has good results w/ the TR cam >> http://forums.corvetteforum.com/zerothread?id=414217
You will also need a good set of springs, pushrods, retainers while you are in there.
Good luck!
[Modified by C5-VERT, 3:53 PM 10/23/2002]
Old Oct 23, 2002 | 05:17 PM
NJVetteGuy's Avatar
NJVetteGuy
Default Re: Camshaft recomendations 2001 LS1 A4 (C5-VERT)
Call Dave at Cartek, (908)317-4496. He helped me out with questions even before I was one of their customers.
Old Oct 23, 2002 | 07:49 PM
Quick Brick's Avatar
Quick Brick
Default Re: Camshaft recomendations 2001 LS1 A4 (NJVetteGuy)
Depends where you want the power. We did a buddies car with 02 Z06 cam and LS6 heads. It runs very well with bolt ons. I have a 224 on 112 and it chops a little and moved the power band UP it picks up around 3800 and pulls to a high 6800 or more. I am scared to take it up that high. You may want a smaller cam to make better power with the tight stock converter. I agree a 114 or more is better for idle and auto's. Let us know! :seeya
Old Oct 23, 2002 | 08:01 PM
CJS's Avatar
CJS
Default Re: Camshaft recomendations 2001 LS1 A4 (Quick Brick)
ThunderRacing .220/.553/114 is what I came up with after months of research. I am using it with stock 2002 Z06 heads.
Old Oct 23, 2002 | 10:56 PM
wm_sorg's Avatar
wm_sorg
Default Re: Camshaft recomendations 2001 LS1 A4 (CJS)
Thanks Guys. I was considering the thunder racing cam also. Unfortunately, it will be more less cost effective because I will have to purchase springs, etc.
Not too big of a deal, but it may mean putting a converter on the chopping block. How does the cam perform with the stock converter?
Old Oct 24, 2002 | 09:15 AM
vstella's Avatar
vstella
I've been there and KNOW what your looking for.. :yesnod: After much research and talking with all the vendors and tuners I took advantage of Agostino Racing Engines Head and cam package. I'm running their agressive stage 1 heads and a Lunati 226/226/554/114 cam..Monster power for a A4!
Mind you, Now you need to get it to the ground which entails a higher stall converter and Drag radials..not to mention you will probably blow up the stock tranny after a very short while. The transmission was not designed for that kind of power..Check out my home page ..It details ALL my mods with pics and race videos ..:D
Old Oct 24, 2002 | 01:14 PM
wm_sorg's Avatar
wm_sorg
Default Re: Camshaft recomendations 2001 LS1 A4 (vstella)
Great site. You are right. I think I am opening up a can of worms.
Old Oct 24, 2002 | 05:06 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
I also went with the B1 221/559/114 with good results, picked up 43 rwhp with the UDP. Go at least with a 114 LSA for the A4. I need a new dyno after so many mod upgrades.
To Camshaft recomendations 2001 LS1 A4
